August 06, 2026, 05:50:16 pm
Hoffman Amps Forum image Author Topic: Power supply question about a Gibson GA-25RVT Hawk  (Read 4746 times)
Offline tkreeve
« on: January 08, 2024, 04:30:51 am »
Hi all. Long time lurker, first time poster.
I'm seeking some advice from the more experienced and educated than myself - schematic attached. The voltages on my unit around 10% of the schematic, which is good - I had it with a tech a few years ago, before I got into electronics myself. It took him 2 years to restore it, and by the time I'd gotten it back I'd learned a little bit. I do not know why, but he'd replaced R42 (last dropper) with a 47K, which about halved the specified voltage on that node. I changed it back to 4.7K and the voltages returned to as specified, but then I noticed R43 starting to burn up (it was a 3 watt wirewound).
I temped in a 5 watt wirewound and measured the dissipation across it about 2 watts - I guess my question is does this appear normal? From what I added up of all the valves downstream of R43, the total dissipation would be about 5.8 watts, unless I did it wrong. Is this just a badly designed power supply, or am I missing something?
Couple other things I found was that V4 (12au7 interstage driver) gets quite toasty compared to the other 12au7 on the same node (have tried other valves with no change - components, voltages around them in spec.) The other thing was the reverb circuit is pretty hummy when engaged, irrespective of tank placement or valves used. I thought about trying to measure the turns ratio of this to see if there was a shorted turn maybe - but I haven't been able to find the original specs, so I subbed in a fender reverb driver briefly and it didn't appear to make any changes to the dissipation.  I would appreciate any insight, thanks so much.
TK
Re: Power supply question about a Gibson GA-25RVT Hawk
« Reply #1 on: January 08, 2024, 05:57:21 am »
According to the voltages on the schematic R43 is dissipating 3.6 watts and R42 is dissipating .3 watts. You need to double those actual wattages for a safety factor. I suggest using 5000Ω/10W and 4700Ω/2W.
« Reply #2 on: January 08, 2024, 06:23:19 am »
I agree with Sluckey
May be they tried to go on the cheap with components or used a stock they had
About to verify the transformers integrity see here
Offline tkreeve
« Reply #3 on: January 08, 2024, 06:34:30 am »
Thanks guys. Lots of good information in so few words. Will also go back to the books and figure out why my numbers were so wrong - I used the schem volts too. Cheers
« Reply #4 on: January 08, 2024, 08:20:53 am »
P=E2/R
The schematic shows the voltage on each side of the resistors. Subtract those two numbers. Square the result then divide by the resistor value. That's POWER.
« Reply #5 on: January 08, 2024, 01:00:38 pm »
"same node" but different bias. 10mA at 250V is near 12AU7 max. How about V7? The reverb driver side runs a similar condition.
I also note that V7 is real near the choke, and the small side of the 12AU7 is a voltage gain stage. This looks like a rushed design.
Offline tkreeve
« Reply #6 on: January 08, 2024, 03:09:59 pm »
P=E2/R
And that result of the differences is the voltage drop measured across the resistor - understand why I went wrong now, was doing the power in 2 steps, getting current v/r, then power i v - but using the wrong number as the voltage drop. That’s much simpler. Thank you!
Offline tkreeve
« Reply #7 on: January 08, 2024, 03:39:42 pm »
Thanks. V7 doesn’t get quite as hot to touch - I tried swapping their places as well. I’ll compare the dissipation with the schematic once I order the correctly rated droppers and go from there if needed.
Rushed design - yeah, I’m no expert but it’s very messy in there, and hard to work to on - L-shaped chassis with terminal boards pushed right into the corner. Was not built with service in mind either.
Thanks again
