August 06, 2026, 09:17:39 am
Hoffman Amps Forum image Author Topic: tap testing tubes.  (Read 7639 times)
Offline joesatch
  • save me from myself.
tap testing tubes.
« on: January 08, 2024, 06:17:50 pm »
for preamp tubes specially V1 how accurate is tap testing them for microphonics? I see many folks doing this but i think in some amps even good tubes will emanate a sound upon tapping on them
Offline Ronquest
Re: tap testing tubes.
« Reply #1 on: January 08, 2024, 06:49:10 pm »
I'd say it's accurate enough to let you know it makes noise when you hit it.
Some tubes make lots of noise when you tap them and some barely.  A few of my favorite tubes (12ax7 and 12at7) are microphonic when you tap them or the chassis, but they don't feedback or sound glassy through the amp when playing.  My amps are  mostly heads, so I can get away with more than a combo.
Offline WimWalther
« Reply #2 on: January 08, 2024, 07:27:20 pm »
Most tubes are microphonic to some degree, this is just the nature of the tech. The internal electrodes act as the plates of a capacitor. Impinging noise causes the plates to move, producing a signal in exactly the same way a capacitor microphone does.
As far as tap testing, this is exactly how the pro tube graders that I know test them. Just don't use your fingers, use a plastic pen like a Bic or a Sharpie to do the tapping.
« Reply #3 on: January 08, 2024, 08:15:36 pm »
There IS a tool for that.
https://el34world.com/Forum/index.php?topic=22130.msg313288#msg313288
keep reading
Offline glass54
« Reply #4 on: January 08, 2024, 10:09:03 pm »
Improvise (steal an appropriate device from the kitchen)  :l2:
"To measure is to know"
Offline joesatch
« Reply #5 on: January 08, 2024, 10:12:42 pm »
i ask this cause i put in a brand new JJ in v1 on a build and tapping it definitely gave a loud clank sound. other tubes in v1 of this amp too clanked. the only one that didn't was a ruby 7025 i guess cause they are lower gain. i think tapping preamp tubes is hogwash.
« Reply #6 on: January 08, 2024, 10:35:16 pm »
The 7025 has the same gain as a 12AX7. But it is like a high quality 12AX7 and has low noise/hum characteristics. There was a time when Fender used 7025s in the signal path of their amps.
http://www.tubebooks.org/tubedata/HB-3/Receiving_Tubes_Part_2/7025.PDF
Offline WimWalther
« Reply #7 on: January 09, 2024, 12:16:22 pm »
keep reading
I have to admit, this one is new to me. Amazing. And silly.
But the CBS/Hytron pin straighteners are great, fwiw.
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #8 on: January 09, 2024, 03:15:23 pm »
is it true that short plate 12ax7 are less microphonic than long plates?
have also heard that long plate 12ax7 "sing" better that short (assuming sing might mean more sustain?)
Offline acheld
« Reply #9 on: January 10, 2024, 09:56:05 am »
I dunno.   It makes "sense" that the long plates might be more microphonic though after thinking about this some years ago I don't think it really does.
I bought a fair number of Sovtek 12AX7LPS tubes awhile back by mistake -- did not register the "LPS" somehow.  When I got them I was concerned that the long plates would be susceptible to feedback, so went about testing them at various positions in my builds.   Never found any problems . . . and those tubes have stood up very nicely over time.
Offline Ronquest
« Reply #10 on: January 10, 2024, 10:00:22 am »
Do those same tubes "clank" in your other amps?  The amount of "clank" is circuit dependent.
« Reply #11 on: January 10, 2024, 10:31:10 am »
« Last Edit: January 10, 2024, 10:33:20 am by kagliostro »
« Reply #12 on: January 10, 2024, 10:54:28 am »
Quit messing around and get a real tool for the job!
Crowbar used in attack - North Bay News
Offline WimWalther
« Reply #13 on: January 10, 2024, 11:48:41 am »
"If I can't fix it, I'll fix it so it can't be fixed."
Offline Lectroid
« Reply #14 on: January 10, 2024, 04:49:48 pm »
My motto:
"If it jams, force it.  If it breaks, it needed replacing anyway."
Magis bos clocca!
Free Beer Tomorrow!
Offline AlNewman
« Reply #15 on: January 10, 2024, 05:39:32 pm »
Some are certainly more microphonic than others.  You did your due diligence in trying other tubes with the same result.
I think a fingernail works for detecting Jimi type feedback on the 1st stage.
« Reply #16 on: January 10, 2024, 06:05:01 pm »
« Reply #17 on: January 10, 2024, 06:25:41 pm »
Since the first day this thread started I remembered that I had some documentation in my archive but I only managed to find it now
« Reply #18 on: January 10, 2024, 06:31:30 pm »
Other
« Reply #19 on: January 10, 2024, 06:31:57 pm »
Other
