August 06, 2026, 07:34:13 am
Hoffman Amps Forum image Author Topic: 5879 in a combo?  (Read 4587 times)
Offline clyde
5879 in a combo?
« on: January 16, 2024, 04:30:44 pm »
Anyone done this?  I've tried an EF86 in the past, no go because of microphonics so I'm wondering if the 5879 would be better.
Re: 5879 in a combo?
« Reply #1 on: January 16, 2024, 04:38:50 pm »
A friend has build a Gibson Les Paul GA40 that uses 5879 tube
https://el34world.com/charts/Schematics/files/Gibson/Gibson_ga40.pdf
However the use of anti vibration socket is highly recommended
« Last Edit: January 16, 2024, 06:50:45 pm by kagliostro »
« Reply #2 on: January 17, 2024, 06:24:36 am »
I've used a 5879 numerous times in a combo preamp.  HoSo56 & the Minimalist and the D'Mars and Carolina Overdrive Special are good examples. There are schematics for those here:
HoSo56 minimalist (el34world.com)
HoSo56 amp (el34world.com)
D'Mars OD Special (Hoffman) (el34world.com)
D'Mars 5879 ODS & FX (el34world.com)
Carolina Overdrive Special 5879 plus (el34world.com)
Offline clyde
« Reply #3 on: January 17, 2024, 02:37:21 pm »
I can't seem to access the schematics as my browser (Safari) either says there's no app if I can download or "404 attachment not found" if I can't.
« Reply #4 on: January 17, 2024, 07:45:57 pm »
Some of those links may not work. But enough of them do that you shouldn't have a problem seeing a schematic for each of them.
You'll need ExpressSCH which is a free download to open those schematics. That's what many if not most of us use to draw schematics up.
If you're using an Apple product, you may need to switch to PC instead.
Offline clyde
« Reply #5 on: January 17, 2024, 11:12:27 pm »
Thank you, I've found a few schematics I can open and this is almost exactly what I was pondering.  Hmmm, but the move to a PC is not something I'm pondering.  ;-)
Offline Lectroid
« Reply #6 on: January 18, 2024, 07:55:22 am »
I use a Mac.  JSchem will open .SCH files, never used it for editing.  I use DIYLC for the Mac.
I've also had good luck using the 6SJ7 pentode, it's fairly quiet with a couple of damper rings on it.
« Last Edit: January 18, 2024, 07:57:30 am by Lectroid »
Magis bos clocca!
Free Beer Tomorrow!
