September 15, 2026, 10:00:36 am
Hoffman Amps Forum image Author Topic: Original Crybaby GCB-95: behaving like a Treble knob  (Read 17016 times)
Offline GuitarPilot65
  • Music by Lee/Lifeson; Lyrics by Peart
« on: March 10, 2024, 03:18:51 pm »
Annoying issue: when I switch it on it "wahs," but it's as if it also turns into a treble knob which is pegged at 10. Tone returns to normal when Crybaby is switched off. Any diagnostic feedback is appreciated.
1993 Brown Fender '63 Vibroverb RI (6G16)
1994 Blonde Fender '65 Deluxe Reverb RI (AB763, modified [by me])
Re: Original Crybaby GCB-95: behaving like a Treble knob
« Reply #1 on: March 10, 2024, 04:22:42 pm »
slipped gear
Offline Beezerboy
« Reply #2 on: March 11, 2024, 03:27:53 am »
check the relationship of the rheostat gear on the pot and the rack gear operated by the pedal. should have full (normal) treb when the pedal is depressed
thats all I got
« Reply #3 on: March 11, 2024, 03:23:53 pm »
slipped gear
I appreciate your response. Would you please elaborate on what you mean by "slipped gear"?
« Reply #4 on: March 11, 2024, 04:11:44 pm »
It means the gear on the pot may have slipped on the pot shaft or the ratchet arm and now needs adjustment. Disengage the gear and rotate the pot manually. If you can get your sweet wah sound then all you have to do is realign the gear on the pot or rotate the pot body until you are in the right wahwah range of rotation. This may take several tries before you are satisfied.
That crybaby does not use the entire 300° pot rotation so even when replacing a pot you still have to do the alignment.
« Reply #5 on: March 13, 2024, 09:20:40 pm »
Thank you, Sir. I'll let you know how it goes.
