August 29, 2026, 09:07:53 am
Hoffman Amps Forum image Author Topic: Dual Cathode Resistors  (Read 8075 times)
Offline clyde
« on: March 20, 2024, 08:35:43 am »
Is there any way to mitigate the "pop" when switching a second one in or out?
Re: Dual Cathode Resistors
« Reply #1 on: March 20, 2024, 08:42:34 am »
Try putting a big resistor across the switch contacts. Maybe 100K or higher.
Offline clyde
« Reply #2 on: March 20, 2024, 09:04:20 am »
No, unfortunately it doesn't seem to do anything, went 10k and lower even.
« Reply #3 on: March 20, 2024, 09:11:35 am »
the further you go down the signal-path, the louder the pop.
are you switching the cathode side or the ground side?
you could do some creative math so you never "break" the path, just parallel a 2nd resistor to = your "new" resistor.
« Reply #4 on: March 20, 2024, 09:24:41 am »
I said maybe 100K or higher. Shooter has a better idea.
There are a few different ways to wire this. Show us exactly how you have your switch connected. Simple schematic.
Offline clyde
« Reply #5 on: March 20, 2024, 09:39:10 am »
I am switching the ground side, so resistor is attached to the cathode.  I used my decade box, started with 10M across the switch contacts,going lower until it didn't make any sense anymore.  The second resistor is switched in for a warm gain increase, 2nd stage 6J5.  I could try switching the cathode side.  In any event, it's not harmful but an annoyance.
« Reply #6 on: March 20, 2024, 10:15:30 am »
Which switching method are you using (A or B)? Or are you using something else?
Offline clyde
« Reply #7 on: March 20, 2024, 10:24:04 am »
"A"  I never thought of using "B", the 2nd resistor half the value of the first, or thereabouts.  It might solve the problem.
« Last Edit: March 20, 2024, 10:26:19 am by clyde »
« Reply #8 on: March 20, 2024, 10:27:29 am »
Is there a bypass cap involved?
Offline SnickSound
« Reply #9 on: March 20, 2024, 10:52:10 am »
Doing this changes the bias point, I don't know of any way of getting rid of the pop beside pulling a Mesa and muting the amp while switching is happening
Offline Esquirefreak
« Reply #10 on: March 20, 2024, 11:45:56 am »
I recently tried switching a preamp triode Rk in parallel with another and could not get rid of the pop. Didn't seem to make any difference with snubber resistors. I suppose that's the nature of switching DC.
/Max
Offline clyde
« Reply #11 on: March 20, 2024, 01:40:56 pm »
No bypass cap.
« Reply #12 on: March 20, 2024, 03:15:31 pm »
what's the end-game you're looking for by on the fly re-bias?
« Reply #13 on: March 21, 2024, 03:03:33 pm »
From this proposal of Mr. Merlin, see option C
Something to which you can give a try
« Last Edit: March 21, 2024, 03:09:35 pm by kagliostro »
Offline clyde
« Reply #14 on: March 21, 2024, 07:44:32 pm »
It's a warm gain on the 2nd stage as stated above, not really "on the fly" but noticeable when switched with the amp on.  This is a restomod of a trashed Harmony H194 which has only volume and tone and I'm just trying to get a little more of an expanded tone palette.  The volume has a pull-on cathode cap on the first stage as well.
« Reply #15 on: March 22, 2024, 01:05:34 pm »
... It's a warm gain on the 2nd stage as stated above ...
May be something like this ?
Offline clyde
« Reply #16 on: March 22, 2024, 03:35:25 pm »
Tres cool, unfortunately I don't have room for a pot, but thank you very much!
« Reply #17 on: March 22, 2024, 03:46:18 pm »
You are not obliged to use a pot on the faceplate
you can simply use a trimmer to find the right values and then resistor and SPDT switch
Offline SnickSound
« Reply #18 on: March 22, 2024, 04:05:00 pm »
That brings us back to the original problem though, hard switching the cathode resistor changes the bias point and will always result in a pop.
The LDR is a nice idea, complicated, but nice.
I would probably just try to get what I want a different way
« Reply #19 on: March 23, 2024, 03:59:51 am »
Also the pot that feeds the LED can be changed using resistors and a switch
