September 19, 2026, 08:14:06 pm
Hoffman Amps Forum image Author Topic: General FX400 conversion  (Read 31135 times)
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: General FX400 conversion
« Reply #50 on: May 21, 2024, 07:16:26 pm »
50V/.045= 1111R
.045 * 50V = 2.25 W
Do you mean 250v instead of 50v ?
Where is the 50 from ?  :w2:
« Last Edit: May 22, 2024, 12:59:27 am by uki »
https://soundcloud.com/ukiuki
Offline AlNewman
« Reply #51 on: May 21, 2024, 07:31:47 pm »
Don't you want to drop 50ish volts?  From 300-250?
« Reply #52 on: May 22, 2024, 08:04:30 am »
A+ 311v at node, 300v at Pin5 PAB+ 242v at node; after the screen R, 240v at Pin6 PA
my idea was to USE TAB B as the PA AND the screen, the 470 to "limit" current at G2
TAP A isn't used.
Offline uki
    • Uki's Guitar Trip
« Reply #53 on: May 22, 2024, 08:48:30 am »
I did it but voltage was dropping to 160v ish. and AB R was going really hot.
« Reply #54 on: May 22, 2024, 10:37:57 am »
 :laugh:
change the dropping resistor from 8.5K to something like 500 ohms then try
(use gator clips! you'll be tweaking a couple times to "get it right")
Offline uki
    • Uki's Guitar Trip
« Reply #55 on: May 22, 2024, 11:35:59 am »
I did put a 2.2k/5w resistor between rectifier and A, now the A does read 260v and plate voltage right at 250v !!!
now just have to adjust B,  it went down to 235v ish,
Oh yeah thanks !!   :worthy1:
now a side thing, filter caps are draining rather fast after turn off , no bleed resistor, new ones 22uF/400v  any thoughts ?
Online sluckey
« Reply #56 on: May 22, 2024, 01:18:01 pm »
WAG... Maybe the cathode of the 6AQ5 stays hot enough to keep the tube conducting for a short time after the power is turned off. That would drain the filter caps quickly.
Offline uki
    • Uki's Guitar Trip
« Reply #57 on: May 22, 2024, 02:00:23 pm »
WAG...
What WAG mean ?   :icon_biggrin:
[Maybe the cathode of the 6AQ5 stays hot enough to keep the tube conducting for a short time after the power is turned off. That would drain the filter caps quickly.
Well the PA tube does go really hot in temperature!
I think i got the amp tuned with conservative voltages!
 It does sounds good, smooth tone,
volume wise it is warm at 5-6 driving at about between 7-8
check it out the voltages:
after rectifier 318v
A+ 247v
B+ 230v
C+ 205v
V1 p1 0v
     p2 0.866v
     p7 84.5v
V2 p1 0v
     p2 1.3v
     p3 158v
V3 p1 0v
     p2 2.5v
     p7 189v
PA-V4
    p1 0v
    p2 14.6v     cathode resistor 474ohms
    p5 237v
    p6 229v
Does this sounds right? Any suggestion or advise ?
Thanks !!
« Last Edit: May 22, 2024, 02:06:25 pm by uki »
Online sluckey
« Reply #58 on: May 22, 2024, 03:15:57 pm »
WAG means Wild Ass Guess. It really wasn't such a wild guess but it's the first time I've used that logic on this forum.
I worked on an ARSR radar transmitter for forty years. The transmitter tube ran the filament current at 50A while in standby. As soon as the transmitter was energized a big motor driven variac would slowly bring the high voltage up. As soon as the transmitter tube was drawing 50mA, the filament circuit was shut down. No need to keep baking the cathode because the cathode current was enough to keep boiling electrons. My WAG was partially based on this transmitter tube that didn't even need a hot filament to keep operating.
Offline uki
    • Uki's Guitar Trip
« Reply #59 on: May 22, 2024, 03:31:29 pm »
WOW    :blob8:
Now that you mention it the heaters are running at 6.7 i think, something close to that, i did a reading there after a re-solder cos of a bad contact. There was one more tube in the original circuit, with no load the heater read 7v. So probably with that 6th tube the heater would be closer to the 6.3v, maybe that is the reason PA tube is running so hot ?
« Reply #60 on: May 22, 2024, 04:13:49 pm »
WOW
Steve worked on the big-boy Radars, the one I worked on, my PA probably wouldn't be big enough to drive his PA
those tubes run finger-blister hot, ask me how I know
the math says you're around 7w dissipation so it's cool, just don't touch the tube to prove it :icon_biggrin:
Online sluckey
« Reply #61 on: May 22, 2024, 08:21:56 pm »
Yeah, that ARSR-2 had a 5MW amplitron for the output tube. The driver was a 500KW magnatron.
Offline uki
    • Uki's Guitar Trip
« Reply #62 on: May 23, 2024, 01:40:12 am »
« Reply #63 on: May 23, 2024, 01:52:26 am »
 :laugh:
that's hair-on-fire kinda power!
were they CW?
most of the TX stuff I worked on was pulsed-power, 25Kw was as far as I ever got, or ever wanted to.  I'd walk into the 5MW shack and I could feel my electrons aligning  :icon_biggrin:
Online sluckey
« Reply #64 on: May 23, 2024, 08:14:32 am »
were they CW?
No. Pulsed. 2µS pulse width and 360 PRF. The 5MW output power was only about 3.6KW average power.
« Reply #65 on: May 23, 2024, 08:43:59 am »
 :laugh:
only 4KW
the "beam" was a 5KW CW klystron PA, everything else i've worked on Radars, MRI's, have been pulsed.
whenever I went up to the 5MW search radar, i did "sense" something, was weird, almost like walking up to a 3Tesla magnet.
sorta like the rock song "Can you smell that smell..."  it was like "can you feel that force"  only met one other tech, military or civilian that "thought something is different now"
good times!
thanks
Online sluckey
« Reply #66 on: May 23, 2024, 09:28:17 am »
Oh they definitely have a feel in the air and 360 pulses per second has a definite sound! Our radar was also used by the USAF so we would get a yearly inspection. The eval team had id badges that had a neon bulb built in. It would light up whenever they got in a danger zone.
Sorry for the derail uki.
Offline uki
    • Uki's Guitar Trip
« Reply #67 on: May 23, 2024, 09:47:00 am »
It is all good im enjoying it !!  :icon_biggrin:   The amp is almost done anyway, I may tweak the PS a lil bit more, working on the case/box now.
What is:   2µS  ?
« Last Edit: May 23, 2024, 10:15:26 am by uki »
« Reply #68 on: May 23, 2024, 10:38:18 am »
micro second, 1/1000th of a second
in order to "exceed" manufacturer's suggested operating conditions you only turn "on" the PA for a real short time
Online sluckey
« Reply #69 on: May 23, 2024, 10:42:09 am »
What is:   2µS  ?
It's a very, very short time... 2 microseconds
When the transmitter fires that 2µS pulse out the antenna, it only takes 12.36µS for that pulse to travel 1 mile, strike an airplane, and return to the antenna and receiver. IOW, 12.36µS equals one radar mile. 12.36 is a number that is ingrained into every radar technician's soul. It's all about time.
Online sluckey
« Reply #70 on: May 23, 2024, 10:43:35 am »
One microsecond is 1/1,000,000 of a second.
« Reply #71 on: May 23, 2024, 12:29:17 pm »
 :laugh:
been wood cutting, splitting, stacking, math isn't getting though today
Online sluckey
« Reply #72 on: May 23, 2024, 12:47:19 pm »
That's a lotta stuff in that small box. I like unusual projects like this. What was originally in that box?
Offline uki
    • Uki's Guitar Trip
« Reply #73 on: May 23, 2024, 08:10:00 pm »
It was a reel-to-reel recorder.  Pics on 1st post.
It had a lot more stuff stuck inside, i got rid of the reel machine, it was really heavy, now its like 1/3 of the weight.
About 90% done , still need some nice panel, actually two, ill add one for the controls and another bellow above the PT and speaker for the power switch, fuse hold, and pilot light. Also a finishing for the baffle, looks sloppy.
Its operational and going for a gig tomorrow !!!  :m8
Got pics !  :icon_biggrin:
PS more here
« Last Edit: August 13, 2026, 02:56:15 pm by uki »
