September 08, 2026, 02:54:14 pm
Hoffman Amps Forum image Author Topic: caps& resistors role in vibrato circuit   &nb  (Read 6374 times)
Offline Geezer
« on: June 18, 2005, 05:57:45 am »
        > caps& resistors role in vibrato circuit
<< Prev Topic | Next Topic >>
Author  Comment
tubenit
Junior tube assistant
(3/31/04 4:41 pm)
 I am wondering what role resistors (and caps) play in a vibrato (tremolo) circuit. For example: In a circuit you might have a 1M resistor prior to a .01 cap "coupled" to another 1M resistor to a .01 cap "coupled" to a .02 cap going to a 3M pot & 100K resistor (such as on a Princeton Reverb). I discovered that changing one of the.01 caps to a .02 cap seemed to either deepen or slow the vibrato (in a way that I like). What do the resistors do and if I changed one to a higher (such as a 1M to a 1.5M or 2.2m) or lower value how would that impact the sound. Thanks for ALL the info and help - it helps! tubenit
tubenit
(4/1/04 8:10 am)
 Re: caps& resistors role in vibrato circuit
 Going back and reviewing schematics of 3 amps I am familiar with, it appears that the higher "speed" vibratos have higher resistor values. Would it be accurate to assume that this thinking would be headed the right direction? For example if I replace a 560K resistor with a 1 M that the vibrato speed would increase (or deepen?). Any feedback would be appreciated. Thanks!
zachsdad
(4/1/04 10:02 am)
 Phase Shift Oscillator
 Below is a simple description of a phase shift oscillator and the resistor/capacitors I believe you are referring too. Notice that changing the component values change the amount of lead/lag and therefore the frequency of oscillation. This is an excerpt from "Electronic Principles (Second edition p.537) by Albert Paul Malvino" You can probably find it in any college library if you want to research more.
Leslie
Edited by: zachsdad at: 4/1/04 10:09 am
tubenit
(4/1/04 5:27 pm)
 Re: Phase Shift Oscillator
 Thanks for the resource and the help! tubenit
Tiny Daddy
I will work on all amps
(4/1/04 7:38 pm)
 Thinking of this another way, what you have is a multi-section low-pass filter that provides a 90 degree (or more)phase shift. The amplifier (tube) provides another 180 degrees of phase shift plus gain. So when the input is connected to the output the circuit oscillates at the
filter's -3dB point which is where the filter's phase shift occurs.
 Topic Commands
Powered By ezboard® Ver. 7.32
