September 17, 2026, 06:47:01 am
Hoffman Amps Forum image Author Topic: SLO100 build lost B+  (Read 10310 times)
Offline hiegdk
  • Tube noob
« on: April 29, 2024, 11:07:53 pm »
So my SLO100 clone, which I've been using happily for a almost 2 years blew a mains fuse the other night. I just got it on the bench and I'm only able to measure the HT on one side of the choke. In reference to the attached schematic with the power tubes out of the amp I'm measuring 530V at E and about -0.5V at D. Does that imply that my choke died?
Offline glass54
Re: SLO100 build lost B+
« Reply #1 on: April 30, 2024, 12:32:45 am »
Quite possibly!
...and there may be a culprit  :laugh:
(Amp unplugged!) Check C31, 32 and 33 with your multimeter on ohms. May be very unwell?
Regards
Mirek
"To measure is to know"
« Reply #2 on: April 30, 2024, 08:00:57 am »
Check resistance between nodes E and D. Should be relatively low. Check resistance from node D to ground. Should be relatively high.
« Reply #3 on: May 01, 2024, 05:55:42 am »
or the filter cap at that end of the choke
Offline Latole
« Reply #4 on: May 01, 2024, 03:35:01 pm »
Choke ;
1- read coil ohm
2- Disconnect choke at D and read voltage.
    A good choke will read same voltage you read at E
Offline hiegdk
  • Tube noob
« Reply #5 on: May 02, 2024, 11:07:09 am »
Resistance between E & D is infinite (OL on my meter). Resistance from D to ground is about 2M. Seems bad :laugh:
Offline hiegdk
  • Tube noob
« Reply #6 on: May 02, 2024, 11:30:41 am »
Choke ;
1- read coil ohm
520V at E and about 3V at D...
« Reply #7 on: May 02, 2024, 11:40:23 am »
You need a new choke but the filter caps are likely good. A shorted cap did not kill the choke. Maybe a bad output tube caused the choke to fail.
Offline hiegdk
  • Tube noob
« Reply #8 on: May 02, 2024, 12:22:48 pm »
Thanks - ordered a new one.
I've also noticed some discolouration of the 100R balance resistors in the faux center tap on the heaters (photo attached). Should I replace them with a higher wattage ?
« Reply #9 on: May 02, 2024, 12:48:23 pm »
Replace them with 1/2 watt resistors. Those burned resistors are a sign of output tube failure, usually plate to heater short, or screen to heater short. Since your choke was also burned up, the screen was most likely shorted to heater. You will likely burn up another choke if a shorted tube is not replaced.
Offline hiegdk
  • Tube noob
« Reply #10 on: May 02, 2024, 01:12:04 pm »
Ok, perfect, thanks - I have a new set of tubes on order already. Maybe I'll double check the wiring at the tube sockets too to make sure I don't have any shorts there.
Offline Latole
« Reply #11 on: May 02, 2024, 02:40:03 pm »
Choke ;
1- read coil ohm
I meant to measure the voltage on the choke, side D and not on D itself where, of course, there would be nothing.
The aim was to check whether the choke is conducting or not.
And I've read that it doesn't.
You'll have to replace it after fixing the problem that caused its destruction.
« Reply #12 on: May 02, 2024, 02:56:39 pm »
Good idea. Look for any signs of arcing or burns on the sockets. Also check for any resistance between all output tube socket pins 3 and 2 and also between pins 4 and 2. Do this with and without the tubes plugged in.
Offline hiegdk
  • Tube noob
« Reply #13 on: May 03, 2024, 12:37:57 pm »
So I'm reading around 1M resistance between pin 2 and D with no tubes in, the choke disconnected, and the lead from D to the screen grid resistors disconnected.
Offline hiegdk
  • Tube noob
« Reply #14 on: May 03, 2024, 12:45:48 pm »
Over time that resistance has drifted up to over 10M
Offline hiegdk
  • Tube noob
« Reply #15 on: May 03, 2024, 12:50:42 pm »
Disregard - probe clips were loose. Reading open loop between pin 2 &3 and 2&4 of each tube socket.
« Reply #16 on: May 03, 2024, 01:00:37 pm »
Are those resistance readings still open loop with tubes in the sockets?
Offline hiegdk
  • Tube noob
« Reply #17 on: May 03, 2024, 01:03:11 pm »
Yes
« Reply #18 on: May 03, 2024, 01:08:51 pm »
Proceed with caution when you replace the choke. I highly recommend using a light bulb limiter at first startup.
Offline hiegdk
  • Tube noob
« Reply #19 on: May 03, 2024, 01:15:44 pm »
Will do. I have new tubes as well. If the issue wasn't a bad tube what's the next most likely culprit? Filter or reservoir cap(s)?
« Reply #20 on: May 03, 2024, 01:33:20 pm »
Shorted C31 and C32 or shorted tube(s) are about the only logical culprits. It takes a lot to burn open a 200mA choke. Of course, the choke winding could have developed a short to frame.
What was the circumstance when the amp failed? Be specific. There may be some clues.
Offline hiegdk
  • Tube noob
« Reply #21 on: May 03, 2024, 02:21:00 pm »
As best as I can remember I had just moved it and the cab across the room during a recording session. After plugging it all in there was a fair bit of hum after taking it off standby, which I had attributed at the time to a ground loop issue with the DI/splitter I was using in front of the guitar player's pedalboard. During the course of troubleshooting that issue the amp blew it's mains fuse when I popped it out of standby. Took it home and put it on the bench and that's when I diagnosed the missing B+ that started this thread.
Offline Latole
« Reply #22 on: May 03, 2024, 02:28:59 pm »
IMO could be a power tubes failure and a too powerful fuse ( I see 5A on your schematic) who couldn't protect the amp's parts
