September 17, 2026, 01:31:36 pm
Hoffman Amps Forum image Author Topic: Musicman RD 100 2100 Cal Chassis  (Read 8444 times)
« on: May 11, 2024, 08:40:19 am »
The amp is drawing too much current under load. It's been 4 months since getting a rewind Power Transformer from Mercury Magnetics. I can read the (2) 1N5353B Zener Diodes. I can not read the other (5) smaller ones. Does 1N4003 look right? I have an actual layout for the 2165 & 2100 RD but as well they don't list the part #.Musicman made so many different amps and schematics i don't trust knowing if im looking at the right ones anymore.
« Last Edit: May 11, 2024, 08:50:07 am by plexi50 »
Re: Musicman RD 100 2100 Cal Chassis
« Reply #1 on: May 11, 2024, 09:34:44 am »
they should be "good enough" to tell Zener from standard diode, once you figure out they're "regular" diodes you can usually throw in whatever you have based on size n "application".
Diodes typically fail short, then soon burn open, easy enough to test lifting one side.
« Reply #3 on: May 11, 2024, 12:12:32 pm »
What voltages should i use for the IN4003 & 1N5353B Diodes? 16 volts?
Also what is that small white diode whatchamacallit?
« Last Edit: May 11, 2024, 12:16:12 pm by plexi50 »
« Reply #4 on: May 11, 2024, 12:23:28 pm »
What do you mean? You should use whatever voltage the amp supplies. Don't exceed the 200V PIV rating for the 1N4003 diodes. The 1N5353B is a 16V zener. The unregulated voltage applied to the zener must be greater than 16V in order for the zener to act as a regulator.
« Reply #5 on: May 11, 2024, 12:26:57 pm »
What do you mean?
2nd that motion  :laugh:
the bottom side would help to trace the "white" diode, guessing it's D14, a 22v Zener from Steve's schematic
« Reply #6 on: May 11, 2024, 12:30:58 pm »
I have a 32.7 VDC feed to the 370 ohm ceramic resistors before i lifted the board out of the chassis.
Edit: Disregard this info;
« Last Edit: May 11, 2024, 12:59:57 pm by plexi50 »
« Reply #7 on: May 11, 2024, 12:43:22 pm »
I re measuered from the yellow CT wire to each orange lead and i have an even 32 VAC on each orange voltage lead.
Sorry im a mess today.  I know accurate info is needed. Just wanted to know the voltages for the diodes.
« Last Edit: May 11, 2024, 12:58:49 pm by plexi50 »
« Reply #8 on: May 11, 2024, 01:27:17 pm »
Did you get a good answer?
« Reply #9 on: May 11, 2024, 05:42:42 pm »
Yes. Thanks for the Diode voltage info. The amp was messed with before i got it and the underside of the boards traces where the cap's and 370 r resistors meet were really badly soldered. The traces are less than paper thin to start with. I am just going to rebuild the rectification area and Zener Diodes. I know my PT is good. Thanks much.
« Reply #10 on: May 11, 2024, 06:51:51 pm »
did you derive that from the "burnt" area?
I ask because a "bad PS" is usually the result of something else, so rebuilding the PS without finding the cause/source will typically result in a bad PS, again.
« Reply #11 on: May 11, 2024, 07:13:14 pm »
My limiter bulb dimmed and i flipped it off immediately. After pulling the board today i saw some hackery solder work where the caps and diode traces are. I didn't expect to see what i saw. The voltages of Neg & Positive 16 volts were present. Then it disappeared from one of the caps all together. Anyway i am just going to rebuild the entire burnt area. All diodes Rectifier and Zeners & Caps and 2N6292 tube driver transistors. I checked all the PT voltages earlier today and all is good per the Mercury M spec sheet as far as the power transformer itself.
« Last Edit: May 11, 2024, 07:18:58 pm by plexi50 »
« Reply #12 on: May 11, 2024, 08:12:20 pm »
Those zeners get hot. When you replace them leave the leads long enough to allow the zeners to stand above the board by about 1/2".
« Reply #13 on: May 12, 2024, 07:01:10 am »
my understanding, when it's real bright, things are not good.
anyway;
IF the tubes grid (G1) goes short, that could take out the PS since it provides 22vdc with a Zener for part of it's biasing.
« Reply #14 on: May 12, 2024, 07:14:48 am »
I would prefer the 12AX7 PI model myself.
« Reply #15 on: May 12, 2024, 08:26:46 am »
Figured from reading that i would use these transistors instead of the 2N6292.
2N6488 is suppose to be more matched.
« Reply #16 on: May 13, 2024, 08:20:42 am »
Here is a more detailed and clear pic of an amp i did a few years ago. Thank God for record keeping and documents.
 Hard to get good pics with my crappy phone.
