September 18, 2026, 09:35:21 pm
Hoffman Amps Forum image Author Topic: Does someone knows if is possible to find this kind of flat spring ?  (Read 5948 times)
Hi friends
Does someone knows if is possible to find this kind of flat iron spring
Measures are 0.1mm thikness, 6.2mm x 13.8mm and the "small moustaches"  get up 4mm from the base
Obviously we are looking for something that cutted can cover the required dimensions
they are used on this GU-50 Dissipated Sockets to transmit the heat from the tube to the dissipator and to compensate thermal expansions
As this kind of Dissipated Socket is not disposable new and very difficult to obtain used a friend want to try to modify aluminium cilinder dissipators that can be find on the web but he needs the Flat Springs
« Last Edit: May 13, 2024, 08:57:07 am by kagliostro »
Maybe you could remove the inside layer of an IERC tube socket. Probably have to cut the outer solid shield off with tin snips.
Offline j-b-c
  • sparks!
Thanks friends
@ Sluckey
Ciao Steve
I think I've that kind of dissipated shield for Noval tubes
but easily the spring inside will be small, not enough tall and large for a GU-50 tube
@ j-b-c
I've find a dissipation foam pad on the web but it is rated only for 200° and those tube are hot like hell
Offline j-b-c
  • sparks!
Fischer has a selection of silicon elastomers that are good to 250C.  Good enough to withstand molten solder.
Their carbon material goes up to 500C.
It would be ironic if the dissipator ran the tube hotter than naked.  Quartz is quite transparent to radiated heat, but that contact spring is working by convection and blocking much of the radiation that would otherwise pass through the quartz window.
https://www.pgo-online.com/intl/curves/quartz-glass-transmission.html
edit: the 250C elastomers are here ==> https://www.fischerelektronik.de/web_fischer/en_GB/heatsinks/E01.01.000/Thermally%20conductive%20foil%20made%20of%20siliconelastomer/$catalogue/fischerData/PG/WFK25/search.xhtml
« Last Edit: May 13, 2024, 05:24:02 pm by j-b-c »
But you said, "Measures are 0.1mm thikness, 6.2mm x 13.8mm". That converts to .25" x .5" to me. Very tiny!  Maybe you posted the wrong dimensions?
Offline Beezerboy
kina hard to tell the shape but they look like a "U" or a "V".    if so I would just cut a strip of aluminum about 6mm wide and bend up little "V"s, cut to length. unless the alu is dead soft it will have some spring back. might take some practice to get good ones but it shouldn't be that hard. alu is a much better conductor of heat than steel
@ j-b-c
Thanks for the info, very interesting the link
the only thing I can say is that tubes become Hot, very very HOT
@ Sluckey
Me Stupid  :BangHead: :BangHead: :BangHead:
Measures are 0.1mm thikness, 6.2cm x 13.8cm (or 62mm x 138mm) and the "small moustaches"  get up 4mm from the base
 :worthy1: :worthy1: :worthy1:
@ Beezerboy
the shape of the little moustaches is near a U, but on the lifted side the moustaches are shaped to better touch the tube glass, near impossible to be done by DIY
At the moment I'm valutating two materials
https://www.ebay.co.uk/itm/266494964239
and
https://kemtron-emc.com/it/emc/stock-di-bastoncini-in-rame-al-berillio/
