July 25, 2026, 07:40:34 am
Hoffman Amps Forum image Author Topic: ECL84 Reverb in new amp questions  (Read 6308 times)
Offline boodle
« on: July 01, 2024, 09:42:49 am »
Hello all,
I am in the process of updating a new build sonically and will add a one tube reverb while I'm in there.
Schematic pdf attached.  ECL84 datasheet attached.  Moody GA40 reverb schematic trace attached.
4 questions:
1. On another schematic that I was using as a guide, the builder put a 22nF cap between the (treble control) output of the stack and the two 270k mixing resistors.  That seem unnecessary as all DC has been blocked to the TS.  Am I correct in this thinking or am I missing something?
2. The Phillips ELC84 datasheet notes that the pentode has a Ra = 3k @ 170-220V.  First, I am assuming that is the load impedance, could be mistaken.  Also, the pentode plate resistor will be fed at ~270V.
Am I reading this right and, as a result, should use one of the tank codes listed on the schematic, 8EB3C1B or 8FB3C1B?  (Has to be a small tank due to cabinet size, want 3 springs for that sound, want the long decay so that I have max control of decay with the Dwell knob.)
3. A general question regarding the reverb circuit: Do you seen anything that I should change?
I am using a couple of schematics for a guide, one of which is a trace of the Moody GA40's ECL84 reverb.  The Moody has quite a bit of extra stuff on the grid and plate of the ECL84 triode that I have simplified.  I am assuming that the extra stuff is for tweaking the tone of the verb.  I might need to go back and do that, but didn't want to start there.  Also, I moved the reverb level control to before the triode recovery stage.
Thank you for any assistance that you have to offer!
Offline boodle
Re: ECL84 Reverb in new amp questions
« Reply #1 on: July 02, 2024, 11:18:00 pm »
Anyone with thoughts?
Offline Merlin
« Reply #2 on: July 03, 2024, 03:44:36 am »
I haven't analysed the operating point in detail but it looks like a solid circuit. Personally I would just run the driver in triode mode for simplicity (e.g. Traynor), and maybe increase the 2.7k load resistor a bit to save some current. You want the highest impedance tank you can get.
Offline boodle
« Reply #3 on: July 03, 2024, 11:05:23 am »
Merlin,
Wonderful!  Just what I was looking for.  I appreciate it.
In terms of raising the 2k7, you thinking 10k-ish or do you have some other recommended starting value?
Do you suggest I have any resistance between grid 2 (pin 9) and plate (pin 6) or just tie them together for triode mode?
Proposed updated schematic attached.
Tim
« Last Edit: July 03, 2024, 11:27:46 am by boodle »
Offline Williamblake
« Reply #4 on: July 03, 2024, 11:27:05 am »
Wouldn't you need a mixing circuit?
Offline boodle
« Reply #5 on: July 03, 2024, 11:29:10 am »
Williamblake,
Thanks for looking at it!
I believe the two 270k resistors just after the tone stack are the mixers.  No?
Tim
Offline Merlin
« Reply #6 on: July 03, 2024, 11:35:36 am »
Yes 10k would be fine, and just tie the screen straight to the anode. Traynor for reference (wonderful reverb on those things!): https://el34world.com/charts/Schematics/files/Traynor/Traynor_ygl_3_ygl_3a_mk_iii.pdf
« Last Edit: July 03, 2024, 11:39:11 am by Merlin »
« Reply #7 on: July 03, 2024, 11:52:07 am »
The output signal will probably be much weaker than the signal coming from the first gain stage of your amp.
Offline boodle
« Reply #8 on: July 03, 2024, 01:34:37 pm »
Merlin,
Thank you for the link and advice, very helpful.
Williamblake,
If I am understanding correctly, I may need to reduce the 270k mix resistor coming from the reverb side to get the max verb amount I might want.  Reading you correctly?
Or are you suggesting that I rebias the triode part of the ECL84 for more output?
Tim
Offline Merlin
« Reply #9 on: July 05, 2024, 04:53:40 am »
Yes you can always trim the mix resistors on test, to get the depth you need. Rebiasing won't have much effect on the recovery gain.
Offline boodle
« Reply #10 on: July 05, 2024, 10:09:15 am »
Merlin,
You are a gold mine!  thanks
