September 18, 2026, 12:52:29 pm
Hoffman Amps Forum image Author Topic: Bias pit and resistor FAQ  (Read 4735 times)
Offline Snake5150
« on: November 03, 2024, 12:52:58 pm »
I’m sure I’m not the first to ask. But can someone give a brief rundown of the relationship between bias pots and there tail resistor.
I have a jtm45 planning on using a 25kl pot with a 68k resistor. Would this produce enough range.
I have also read that a 10k is suffient ?
Obviously layman’s answers only as I’m not as gifted with the technical stuff.
Offline stratomaster
  • Don't guess, measure.
Re: Bias pit and resistor FAQ
« Reply #1 on: November 03, 2024, 01:07:58 pm »
Search "resistive voltage divider". You will find everything you need to know.
Offline AlNewman
« Reply #2 on: November 03, 2024, 01:39:03 pm »
The tail resistor between the pot and ground is basically used as a safety net so you always have negative bias at your grids and won't fry your tubes (or OT, or resistors, etc.) by overadjustment.
What you choose as the tail resistor depends on tubes and B+ voltage.  I believe the pot on a marshall circuit is wired as a variable resistor, so you can parallel resistors with the pot to dial in the amount of adjustment you want.
Without all the math, it's possible to figure out using trial and error, if you have an idea of what you want your center bias to be.
« Last Edit: November 03, 2024, 01:43:51 pm by AlNewman »
« Reply #3 on: November 03, 2024, 02:29:51 pm »
best done with NO PA tubes in and measuring bias voltage at the tube side of the power tubes socket.
