September 08, 2026, 10:33:25 am
Hoffman Amps Forum image Author Topic: Danny Gatton tone pot mod! How it is possible?  (Read 19994 times)
Offline Avraxas
  • I am here to learn! Please be patient! :)
« on: November 12, 2024, 07:28:17 am »
If you look at this video at about 12:00 Danny use the tone pot to produce an effect. The weird think is that his pot "works” from 1 to 3 and then from 3 to 10 does nothing! I mean no effect to the tone after 3. Can anyone understand the mod?
For sure there is not the mod that you can find on the internet with 2 capacitors I believe. Cause the internet mod "split" the tone at the half and works like 5-0-5.
Any thoughts?
Offline Latole
Re: Danny Gatton tone pot mod! How it is possible?
« Reply #1 on: November 12, 2024, 09:28:47 am »
At 12:53
In my opinion, it looks like a linear B potentiometer for the tone: the linear potentiometer “gives” its maximum in the very first values, which would explain why from 3 onwards, the tone doesn't appear to change.
According to my research, the usual potentiometers (volume and tone) on a Telecaster are type A logarithmic. This is why volume and tone have a sensed operating range of 1 to 10. Not 1 to 3.
That's the only explanation I can think of.
It's possible that the ohms value of the potentiometer may also contribute slightly.
Offline Avraxas
« Reply #2 on: November 12, 2024, 11:56:22 am »
You mean Audio Log pot I think
« Last Edit: November 12, 2024, 12:20:16 pm by Avraxas »
« Reply #3 on: November 12, 2024, 12:38:27 pm »
No.
That indicates a linear taper tone pot.
Offline Latole
« Reply #4 on: November 12, 2024, 02:10:37 pm »
In the video, in my opinion, the tone potentiometer, which would normally be a logarithmic A, has been replaced by a linear B.
Offline Avraxas
« Reply #5 on: November 13, 2024, 01:54:59 am »
I am so confused. I am talking about 12:30 and about the tone pot only. Not the volume pot. Can’t be a linear pot. This pot it’s not change resistance in equal steps.
Offline Latole
« Reply #6 on: November 13, 2024, 02:32:02 am »
I alway talk about tone pot .
You did not know what is and how work linear pot.
Offline Avraxas
« Reply #7 on: November 13, 2024, 03:14:40 am »
Yes maybe is that but looking at this graph looks like that the higher resistance at 3 have the revesed Log Pot. I am mean, Dannys tone pot it is not correct that at 3 have the almost maximum resistance to be able to get that effect? And from 3 to 10 blend a very small amount of resistance.
 Can anyone explane please?
« Reply #8 on: November 13, 2024, 04:41:08 am »
People learn by experience, I suggest that the best way to understand this stuff is to buy some good pots in the various tapers and experiment.
Offline G._Hoffman
« Reply #9 on: November 14, 2024, 11:19:52 pm »
At 12:53
Honestly, it could even be a reverse audio taper - that seems extreme for a linear taper pot.
Offline Latole
« Reply #10 on: November 15, 2024, 02:57:25 am »
At 12:53
Google ;
What is a reverse audio taper potentiometer?
A 'normal' audio pot wired backwards will have it's 'adjustment direction' reversed, but will have it's range compressed into a small fraction of the turn,
 but a 'reverse' audio pot wired backwards will have it's 'adjustment direction' reversed, but will not have it's range compressed into a fraction of its' turn.
« Last Edit: November 15, 2024, 03:01:13 am by Latole »
Offline Rontone
  • Ixnay on the Ampscray
« Reply #11 on: November 15, 2024, 06:13:26 am »
I tried this years ago on a Fender Japan '52 Tele, a 1meg linear taper tone pot, I cannot remember the cap value, I think a 0.05 possibly
It sure helped sell it on eBay!
On Danny's "Telemaster - Hot Licks" tutorial video, [also about the 12 minute mark] he mentions his pot setup but no values,
I cant quite make out all he says ["the mumbler"] but its something close to:-
"its very important to have a volume pot, that has extremely even gain, the one I have in here isn't the best I've had in my life, but it beats the last one!.....
…..you'll notice the gain is pretty even, the tone pot is exactly the opposite, the tone pot goes from 0-3 and its wide open, like from 3 up it doesn't do anything at all, its negligible what happens.....
.....the drawback of having this kind of tone pot is that if you're playing a jazz gig for instance then you really are trying to find a nice jazz tone but its very sensitive, the area where the tone is gonna be...."
I see a few wiring diagrams for lap steel guitars that come with a 1Meg linear and 0.05 cap and some steel guitar forum posts that suggest some are using 1 meg tone pots
« Last Edit: November 15, 2024, 06:21:03 am by Rontone »
Offline G._Hoffman
« Reply #12 on: November 20, 2024, 11:59:16 pm »
At 12:53
Google ;
But a reverse taper audio pot wired normally would have all it's range bunched up at the bottom of rotation, allowing it to be more easily used for this sort of effect.
