September 08, 2026, 07:33:40 pm
Hoffman Amps Forum image Author Topic: Princeton-ish Reverb design - 12AT7's and Sand!  (Read 12766 times)
Offline Joel
« on: December 13, 2024, 10:01:16 pm »
Hello fine people of EL34World!
I've got the bug again...  I don't need another amp y'know?  But I *do* need another build.  So here we are.
It's predominantly an AA1184 Princeton reverb.  I've re-used the FET-a-Dyne idea I successfully used in my last build (https://el34world.com/Forum/index.php?topic=29299.msg343303#msg343303).   A solid-state Tremolo seemed like a good idea, so I've thrown in one inspired by others on this forum using a pair of LND150's.  These two changes save 3 triode segments.  Nice.  Merlins Transformerless Reverb Driver makes an appearance.  Thanks Merlin!  Saves $80AUD on the iron alone.  I'll be able to afford some McDonalds for dinner!  I've used 12AT7's throughout.  Why?  Because I have soooo many of them.  I used Merlins Load Line Plotter to give what I think will be a good operating point to them all and also provide flexibility to change to most of the common preamp tubes if needed.
Can anyone find any issues or glaring mistakes I may have missed?  Suggestions, comments, queries, and critiques welcomed.  No gripes though.
The mouth of a happy man is filled with beer  - Egyptian Proverb
Re: Princeton-ish Reverb design - 12AT7's and Sand!
« Reply #1 on: December 14, 2024, 04:41:26 pm »
IF you get it built, PLEASE do some soundclips!  This is a very intriguing build and somewhat innovative.
The only critique I would have is using .047 instead of .1 for C24 and C25.
And for V1, I am not a fan of a 12AT7 in that position. It's just a personal preference thing. I don't think that tube is very musical in tone.  I prefer a 5751 or 12AY7 which I think have a better tone. I do use 12AT7's in my amps but just not in V1
I'll be following this thread with some interest.  Thanks for sharing!   With respect, Tubenit
Offline jbrrrrr
« Reply #2 on: December 14, 2024, 05:10:18 pm »
Following this thread - I'm working on a remodel of a single channel Princeton Reverb-type with LND150 recovery and oscillator stages to free up a few triodes to do some other more interesting things.  I might consider a transformerless-reverb or one of the single tube reverb designs also if I'm not digging how this ends up.
Godspeed!  Build it well and post updates frequently please!  :icon_biggrin:
Offline pullshocks
« Reply #3 on: December 14, 2024, 05:40:13 pm »
I don't want to hijack this thread, but......JBRRRRR could you post a schematic of your LND150 recovery stage?  Thanks
Offline jbrrrrr
« Reply #4 on: December 14, 2024, 05:59:34 pm »
I haven't settled on exactly how I want to do mine yet, but here's an example from a Blues Jr. that uses an LND150 for reverb recovery - I might add a source follower to this and tweak the bias a bit but I'll have to do that kind of tuning by ear.  Hope this helps.
I'll post my schematic once I've finished it up in a separate thread for anyone else to mock or find useful.   :icon_biggrin:
Offline Joel
« Reply #5 on: December 16, 2024, 01:48:09 am »
You want soundclips of *me* playing?!?  That's like making someone listen to Vogon poetry (and yes, I realise I'm showing my age here.  Fortunately, I identify as 28 years old, so everyone has to treat me as if I am.  So there!).
Thanks for your feedback.  It's greatly appreciated.  Can you please elaborate on your recommendation for 0.047uF instead of 0.1uF for C24 and C25?  I must admit to simply copying the original and Hoffman's single channel version here.
5751 is my very favourite tube.  Each of my builds has one in it - replacing a 12AX7 with spectacular results.  Each time I plug on into V1 (when the amp is designed for 12AX7 as V1), the amp is better.  Unfortunately, I don't have many left.  It's worth noting that the AX84 "Clean Preamp" uses a parallel 12AT7 as V1.  My Heretic Woke amp uses "Clean Preamp with added gain" and it's *very* nice.  I'm unsure how a single triode 12AT7 will go, but I think I'm willing to give it a shot, especially since I'm not just subbing it for a 12AX7.  The stage is designed for a 12AT7.  That won't guarantee it sounds good I know.  I can always mod the amp afterwards if it sucks.
Offline Joel
« Reply #6 on: December 16, 2024, 01:52:51 am »
Thanks for you input!  Have you seen this: http://www.hawestv.com/amp_projects/amp_solid_tube/fetpreamp_200v1.htm#drain_curves
I was also considering using an LND150 as the reverb recovery, but then I'd have 1/2 a triode free.  I could replicate the parallel AX84 Clean Preamp 12AT7 input stage again, but that's designed for DC coupling to the following stage, and I wanted to try a 12AT7 as a stand-alone V1.
Offline jbrrrrr
« Reply #7 on: December 16, 2024, 07:10:38 pm »
Sorry!  That was just a response to the comment above mine re: my recovery stage - your plans are obviously slightly different.  Any more chat about that side bit can go in a different thread.
It's kind of fun to think about what to do with free triodes IF you can find a way to be happy with MOSFETs in non-audio-path critical places, or places where tube non-linearity probably isn't being employed much.  Parallel stages, extra cathode followers... that's been occupying my brain for past couple weeks and it's been pretty enjoyable considering it allows taking an old circuit like a PR and giving it a few more possibilities without needing to squeeze any more tubes in there.
« Reply #8 on: December 16, 2024, 08:59:04 pm »
I think with your design a .047 instead of .1 will sound less "woofy" and have a clearer more solid sounding tone.
Offline Joel
« Reply #9 on: December 17, 2024, 12:39:50 am »
Thanks.  I had reduced the cathode cap on the first two stages from Fenders original 20-ish uF down to 4.7uF for this same reason.  I'll give the 0.047 a try.
Offline Joel
« Reply #10 on: March 06, 2026, 03:32:40 am »
Here we are over a year later... Schematic attached. As built.
Offline jbrrrrr
« Reply #11 on: March 06, 2026, 09:25:08 pm »
@Joel - how are you liking it?  Anything you feel like reconsidering at this point?
Thanks -
-Justin
Offline jbrrrrr
« Reply #12 on: March 06, 2026, 09:52:45 pm »
Also - I think you have an error at your 6V6 cathodes - I'm guessing those 1r's are meant to be for current measurement in addition to the 470r's?  Unless the 470r's are the screen supply resistor values, in which case you might have forgotten the additional cathode resistor in addition to the current sense resistors.
My mistake - Sluckey's right in the next comment below.
« Last Edit: March 06, 2026, 10:38:18 pm by jbrrrrr »
« Reply #13 on: March 06, 2026, 10:13:47 pm »
This is a fixed bias amp. 6V6 cathodes are fine. No additional resistors needed. The 470s are screen resistors.
Offline Joel
« Reply #14 on: March 07, 2026, 12:14:28 am »
Very minor updates after solving my reverb recovery noise issue (moving reverb recovery cathode bias earth connection point to a quieter spot - reverb RCA input jack)
Replaced 200k resistor to 560k resistor in the tremolo to Intensity control to tame the strength of the bias wiggle signal to the output tubes.
Replaced Mid control to 10k pot for wider sweet spot (for me anyway).
This amp is currently paired with an 4x10" cab loaded with a pair of Jensen P10R's and a pair of Eminence Legend 1028k's.  (Still looking for more P10R's on the second-hand market).
The amp is clean for most of the volume pot sweep.  Really comes alive when turned up past 1 o'clock.  I'm yet to try it with pedals, an attenuator, or a 1x12 cab.
Justin - I'm liking it so far I think.  It's a bit sterile at low volumes, so an attenuator is in order to get the amp cooking a bit.  I think I'll play with V1 bias points over the next few months.  See how that goes.
Offline Joel
« Reply #15 on: March 07, 2026, 12:26:03 am »
Photo for reference.
I made both cabs.  Stained pine with ply baffles.  Made the faceplate on the laser machine at work.
(don't mind the small badly repaired grill cloth hole on the head cab... I made it out of an offcut)
Offline passaloutre
« Reply #16 on: March 07, 2026, 08:52:54 am »
Do you have the schematic in a more visual format?
Offline dogburn
  • Meddling Kid (but older)
« Reply #17 on: March 07, 2026, 09:48:34 am »
Nice looking amp and cab! Where did you get the metal for the faceplate?
« Reply #18 on: March 07, 2026, 10:10:51 am »
Here you go...
Offline Joel
« Reply #19 on: March 13, 2026, 10:28:37 pm »
Version 1.5.
Changed all 82k anode resistors to 100k so all the 12AT7 amplification stages are now 100k/2.2k biased.  Also changed the 1st stage cathode bypass cap from 4.7uF to 22uF.  As I have 250V at power node D, the load line for this setup looks pretty good for 12AT7.  Also makes it plug and play for 5751 or 12AX7.  This change gives each stage a bit more "oomph" and makes the lower volume settings more lively.  The amp still remains clean up until 3 o'clock on the volume, and then it's edge of breakup / slight overdrive territory.  Sounds good to me.  Next up, I will be adding one of my attenuators and trying it in TPS Wet/Dry with my Hoffman single channel AB763 Deluxe Reverb clone (https://el34world.com/Forum/index.php?topic=21047.msg223090#msg223090).
I've added some gratuitously staged pics out in backyard on the unruly grass in the Queensland sun.
The face- and back-plates are laser etched plastic.  I drew up the design in GIMP and got them done on the big laser machine where I work.
« Last Edit: March 13, 2026, 10:30:41 pm by Joel »
« Reply #20 on: March 14, 2026, 04:02:17 am »
Some telemetry and update to schema would be nice to have a look at.  :icon_biggrin:  Very nice workmanship and concept.
--Pete
Offline jbrrrrr
« Reply #21 on: March 14, 2026, 04:04:08 am »
That cab, grill cloth, and faceplate layout/design are all working real nicely together.  Quite the looker!
