August 30, 2026, 09:58:04 am
Hoffman Amps Forum image Author Topic: 7059 tubes? Any potential for audio purposes?  (Read 5941 times)
Offline Opry Audio
  • tube amp bitch
« on: December 13, 2024, 10:02:37 pm »
I got a huge lot of NOS 12AU7, 6SN7, 6L6, 12AT7, and 6V6 tubes. About 10 7059 tubes were included also. I know these were used in ham radio receivers, but is there any potential for audio purposes? Triode on one side and pentode on the other with a 12v heater supply. Maybe some kind of preamp or buffer? I couldn’t find much info besides a datasheet! Curious if anyone has used them for anything interesting. Thanks!
Re: 7059 tubes? Any potential for audio purposes?
« Reply #1 on: December 13, 2024, 11:17:19 pm »
Pentode is only good for 2.8W Pmax. See last couple of pages in this (multi-tube) datasheet
https://frank.pocnet.net/sheets/191/6/6201.pdf
Offline Merlin
« Reply #2 on: December 14, 2024, 04:34:04 am »
A very ordinary 2.8W pentode and a very ordinary 2.5W triode in one bottle. You could use it for practically anything!
Offline danhei
« Reply #3 on: December 14, 2024, 07:38:09 am »
A common use for those pentode-triode tubes in audio circuits is a pentode gain stage DC coupled to a triode cathodyne phase inverter. Examples: Dynaco ST70 (7199 tube) and the Sunn 200S (6AN8).
Looks like your 7059 is related to the 6U8A. The latter has been used a substitute (with an adapter socket) by Dyanco and other users once NOS 7199 got expensive.
Offline Opry Audio
  • tube amp bitch
« Reply #4 on: December 14, 2024, 06:06:29 pm »
Thank you for these examples. According to the datasheet 6AN8 is very similar with some spec differences in plate voltages and amplification factors / heaters. The 12v heater makes it a little trickier to use in a regular amp topology but may attempt to make a lowZ preamp of some kind?
« Reply #5 on: December 15, 2024, 06:57:25 am »
To have a 12v heater power section there are tubes like 1625 (same of 807 or 6L6), GU50 and others
But a PP or a PSE of 6.3v with heaters connected in series can simply solve the problem
« Last Edit: December 15, 2024, 02:55:27 pm by kagliostro »
Offline Opry Audio
  • tube amp bitch
« Reply #6 on: December 15, 2024, 01:42:54 pm »
You think I could get 12v of clean ac with a simple voltage doubler?
« Reply #7 on: December 15, 2024, 03:05:40 pm »
Doubler give you DC, not AC and require a lot of extra AC current
Assuming you simply want to go DC instead of AC you'll obtain (around) 600mA DC from a disposable 1000mA AC
The more, when you use a doubler the DC current will halve so from 600mA you'll obtain only 300mA (from the original 1000mA disposable on AC)
Find and use a 12V transformer, one of those for illumination lamps
Offline Joel
« Reply #8 on: December 16, 2024, 01:59:01 am »
With 12AU7 and 12AT7 - AX84 "Clean Preamp" or "Clean Preamp with added gain" depending on your application.  Combine with any 6V6 SE or PP output stage... Nice sounding amp.  https://el34world.com/Forum/index.php?topic=29299.msg343303#msg343303
The mouth of a happy man is filled with beer  - Egyptian Proverb
Offline danhei
« Reply #9 on: December 16, 2024, 07:03:47 am »
You just need a power transformer with a 12V winding for the filaments, which will supply the 7059 and any 12A_7 tubes. Pairs of 6.3V power tubes can run filaments in series on 12V as kagliostro said. Or if you can’t find a suitable power transformer with high voltage plus 12V for filaments you could use a secondary 12V transformer. Or you might find a transformer with dual 6.3V secondaries you can add together.
Lots of options
