October 01, 2026, 04:33:07 pm
Hoffman Amps Forum image Author Topic: Oahu Tonemaster 230K amp-Change field coil to permanent magnet  (Read 14817 times)
Re: Oahu Tonemaster 230K amp-Change field coil to permanent magnet
« Reply #50 on: September 30, 2026, 06:39:40 pm »
A better version of the schematic
« Last Edit: September 30, 2026, 06:50:16 pm by kagliostro »
« Reply #51 on: October 01, 2026, 12:47:32 am »
Dummyload, what/where would you have used the choke and resistor?  Sorry but I'm confused.
Field COIL acts like a choke and a choke is a COIL - Field coil adds PS filtering, 230K field coil schema shows 612Ω DC resistance - Hammond is 157L 430Ω make up the difference with 180Ω puts PS B+ to 6V6 anodes at near same as the field coil. Won't have the same inductance as the field coil, likely lower, but I'd want the some of the PS LC filtering character and ripple reduction of the original.
How I selected: The schema shows 15V on 6V6 common cathode R of 200Ω so about 75mA at idle - add another 3-4mA for the preamps, and 8-10mA screen/anode when pushed. the Hammond is rated at 75mA conservatively, has a DCR of 430Ω, closest with similar current need and DCR, still short about 180Ω of the 612Ω of the field coil, that's the series resistor. If you're not comfortable pushing 75mA part, find a 100mA part, take that DCR and add what you need to make 612Ω.
--Pete
Offline wsscott
« Reply #52 on: October 01, 2026, 07:47:20 am »
The P-TGC-001 choke I wound up using is a 4H, 50mA choke with 170 ohms of resistance.  So I added a 500 ohm, 5 watt resistor in series.
DummyLoad, What would the difference have been if I had used your selection?
Offline wsscott
« Reply #53 on: October 01, 2026, 03:05:45 pm »
Ok, now this is crazy.
I rewired the 6VAC filaments.  With the PT 6VAC winding disconnected from the circuit, but with its Center Tap connected to ground, I read 7 VAC.  Ok.  So proper voltage coming out of the PT.  No broken wire leads from it even if they're old.
Then when I connect its leads to the terminal strip where the twisted pair daisy-chained filament wiring connects, along with a separate set of twisted pair leads that connect to the Pilot Light, I read only 1.3 VAC at the terminal strip, then 0.65VAC at the first tube on the chain, and less with each tube.
The first tube in the chain is one of the two 6V6S output tubes.  The first filament connection on a tube socket is on Pins 2 and 7 of the first 6V6 tube. One thing that's weird is that Pin 1 on the first of the 6V6's is connected to GND, and that Pin 1 then connects to Pin 1 on the second 6V6.
I'm getting full DC voltage at the Filter Caps. So the Secondary is fine.
I assume something is drawing the filament voltage to ground, but what is going on!
« Reply #54 on: October 01, 2026, 03:41:38 pm »
the 1st quote created the 2nd quote, now you just need to figure out where you went sideways
 :icon_biggrin:
Offline wsscott
« Reply #55 on: October 01, 2026, 03:58:36 pm »
Yep-So I disconnected the first filament lead off the terminal strip where it connects to the 1st 6V6, and checked voltage there and it reads 7VAC.  Its not connected to the tube socket.  Ok.
So then I jumped those leads to the next 6V6 tube's filaments and there it reads 1.3VAC or so. So something in the circuit is bringing it down.
Tomorrow I'll jump the first lead to the filaments on the PI 6SL7 and see what it reads.  I think its somehow going to be fine and that will lead me back to the 6V6's and that weird GND on Pin 1.
