September 08, 2026, 04:43:14 pm
Hoffman Amps Forum image Author Topic: Questions about Rehabilitating a 65 Super Reverb  (Read 48871 times)
Offline Dumbmonkey
Re: Questions about Rehabilitating a 65 Super Reverb
« Reply #100 on: September 24, 2025, 08:05:26 pm »
Photo for your perusal.
« Last Edit: September 24, 2025, 08:08:43 pm by Dumbmonkey »
Offline stratomaster
  • Don't guess, measure.
« Reply #101 on: September 24, 2025, 09:18:18 pm »
A few things:
The first being most likely the problem:
The resistor that comes off the Reverb knob wiper is supposed to be a 470k.  You put in a 470Ω.  You'll get a good bit of gain back and you'll load down the V2b stage less.
Second: those PR01 Vishays are rated to only 350V. It may never be an issue, but something to keep in mind.
Third: I see some FOD (pieces of components, solder balls, etc). It would be good practice to take care of those as you work as they're easy to lose track of later, and they may cause issues.
Recheck your voltages after you put in the proper resistor. I think they'll come more in line.
« Reply #102 on: September 24, 2025, 09:36:06 pm »
The resistor that comes off the Reverb knob wiper is supposed to be a 470k.  You put in a 470R
If you are noticing a significant volume difference, then something must be wired wrong in the vicinity of the reverb level pot and the associated 470k and 220k resistors, ...
Offline Dumbmonkey
« Reply #103 on: September 24, 2025, 10:16:09 pm »
Holy crap.
I am soooo freaking embarrassed.
Thank you both so much! I am ordering resistors tomorrow. I’ll change out those plate resistors as well.
« Reply #104 on: September 26, 2025, 06:39:48 am »
Confusing 470k with 470R, and visa versa, seems to be a fairly common mistake, eg at the screen grid, LTP bias, and this.
I wonder whether the brown / yellow of the multiplier band might be hard to differentiate if the builder has very slight colour blindness?
« Reply #105 on: September 26, 2025, 07:48:13 am »
yep, American "red" n ccp "red" are NOT the same color to most eyes.
the fix is easy; Ohm every R BEFORE you install.  takes 13 minutes longer initially, saves hours later.
Offline Dumbmonkey
« Reply #106 on: October 02, 2025, 07:56:42 pm »
Hi again!
Ok, so my shipment of stuff came in, and wow, that 470K did the trick as far as the volume of the vibrato channel is concerned.(that'll teach me to pay more attention to the multimeter...)  I'm going to deal with the plate resistors, and then remeasure all voltages to post an updated chart.  Hopefully, I'm on the way to getting this thing healthy and out of my basement.
Offline Dumbmonkey
« Reply #107 on: October 08, 2025, 10:55:33 am »
Hi All!
Hopefully, this is going to be my last post on this topic.
Now that my bout with the Dunning Kruger effect has been addressed, and the correct resistor (470k vs 470 ohm) has been dealt with, the volume issue on the vibrato channel is no more. I replaced the problematic plate resistors with more reliable ones (PR02), and cleaned up some sloppy potentiometer wiring. All seems to be working as it should be.  I went through and checked DC voltages, and they all seem to be within specified ranges.
My next steps are to roll some tubes with the old tubes it arrived with, get it back into the cabinet, and get it out of my sight.  Not that I have anything against Super Reverbs, but as this isn't going to be mine, I'd rather it go back to it's rightful owner and I can have my bench back, lol.
Thanks for all your time and assistance with this, I don't think I could have done this without other eyes and knowledge!
