July 25, 2026, 06:55:07 pm
Hoffman Amps Forum image Author Topic: Hum in a sortof 18W amp  (Read 34309 times)
Offline 8wattjack
Re: Hum in a sortof 18W amp
« Reply #50 on: October 10, 2025, 09:46:16 pm »
I see in the schematic that only the normal channel triode uses a sheilded cable. Have you checked that the sheild is not grounded at both ends?
Offline 8wattjack
« Reply #51 on: October 10, 2025, 09:58:54 pm »
Also just checking the grounding scheme in the actual chassis itself. Whats on paper isn't always whats present. I am no expert on the switching problems mentioned but I have fixed a lot of hum and noise issues with checking ground arrangement and looking for ground loops. Sometimes simply foil ending the plate capacitor on that stage can help too. And/or upping the qualty of it. Works in 5150's.
Offline TexasTone
« Reply #52 on: October 11, 2025, 10:07:11 am »
I was having hum problems with a relay board. My solution was using a stereo plug instead of a mono plug. I'm not sure what you are using, but in my case the hum went away when using a stereo plug.
Interesting.  The hum is there with or without a plug.  I'll take a look.
Offline TexasTone
« Reply #53 on: October 22, 2025, 11:04:46 am »
Issue is resolved.
the 60 Hz hum was resolved by changing out the Mojotone Channel Switcher board and DC fan supply for the Hoffman Amps relay power supply board (for both the fan and the relay) and relay board, along with a Cliff jack and LED.
The 180 Hz hum was traced to the LTPI tube.
Thank you to all who responded.
