September 08, 2026, 04:42:23 pm
Hoffman Amps Forum image Author Topic: Testing Bad Filter Cap with a scope for 120HZ hum  (Read 22273 times)
Offline wsscott
Re: Testing Bad Filter Cap with a scope for 120HZ hum
« Reply #100 on: January 16, 2026, 08:49:37 am »
I think that 60hz fuzzy signal is environmental, since it shows up on the scope when the scope isn't connected to the Output jack or even if it is connected to the Output level jack and the amp is unplugged.
So that's probably a red herring!
Offline wsscott
« Reply #101 on: January 16, 2026, 11:45:57 am »
I should add that the guitar cable I'm using has the shield connected at both of its plugs.
In this case, since the Output jack is not presently connected to a ground, I assume that both ends of the guitar cable need to have their shields connected to the plugs or there couldn't be anyway for the signal to return, and thus no sound out of the amp?
« Reply #102 on: January 16, 2026, 11:56:04 am »
I think we're getting close.
optimism is a good quality to have  :laugh:
Offline wsscott
« Reply #103 on: January 16, 2026, 12:05:42 pm »
I unsoldered the cable shield from the plug leaving the Output jack going to the amp, and it didn't make any difference.  There was still the lower level hum, and it still carried the guitar signal to the amp.  I then swapped the cable end for end and that had no effect.
Would there be any risk of a shock hazard if I disconnected the shield on both ends of the cable that connects the Output Jack of the ReVibe (which no longer has its ground lug connected to any ground) with the Input Jack of the Amp?
« Reply #104 on: January 16, 2026, 02:35:27 pm »
that could cause the same problem you're now chasing, shielded cables are typically grounded at ONE end only, typically the "source end"
think of that shield as a giant antenna collecting all the bad things around it, if it's not grounded at either end, all that "junk" builds up, then inductively couples the junk onto the signal (crazy math not included for simplicity:). grounding one end only, all that junk has a "direct pathway" to ground, stopping the junk from coupling into a signal source.  grounding BOTH ends causes what I had to check by moving the scope ground to various points looking for a "ground loop" condition
Offline wsscott
« Reply #105 on: January 22, 2026, 02:32:16 pm »
I thought I would upload an image of the Output signal from the ReVibe.  I injected a 1khz/150mVRMS signal into the input, and the image is the output of that signal with the Output Level being at "parity" (I know that's not the correct term, but I can't remember what the proper term is) with the Input signal.
It's pretty smooth, but you can see some "blurring" on the edges of the sine wave.  I'm assuming that's the 120hz hum that I've been dealing with.
Is there some way that I can use the scope to identify the reason for the blurring, ie. if it is the hum how can I get the scope to "dissect" the signal into its components?
« Reply #106 on: January 23, 2026, 07:26:37 am »
adjust the Fq per div so that the sinewave is "stretched" out till you start to see something coherent
Offline wsscott
« Reply #107 on: January 24, 2026, 11:02:11 am »
Shooter-I lowered the amplitude of the Output level and got this image of the 1khz signal.
It doesn't mean anything to me because of my lack of knowledge, but maybe it tells you something?
« Reply #108 on: January 24, 2026, 11:54:44 am »
keep the 1khz signal, set it to about 100mvPP, snap a pic.   switch the scope to the FFT function n snap a pic.  post pics
Offline wsscott
« Reply #109 on: January 24, 2026, 12:28:15 pm »
Here you go.
« Reply #110 on: January 24, 2026, 04:40:54 pm »
 :l2:
you win!!  UNCLE!!!!!
you need to find a 20yr old nerd in the family
make it a challenge, offer a reward for positive outcomes, keep them in nerd supplies
this is a shot of an intermittent that kept me going down the rabbit holes;
you have the main freq (Fo) on the left, here should be "decaying" harmonics to the right as mine shows, then the problem-childs are in red n intermittent.
Offline wsscott
« Reply #111 on: January 25, 2026, 06:29:04 am »
I’ve got one, but he’s just 13 now, and I think he’s starting to focus on bigger problems than mine, ie. Girls!
« Reply #112 on: January 25, 2026, 09:00:47 am »
 :laugh:
by the time I was 13 dad had taught me the basics of soldering n "reading the pictures"...schematics. by 14 I was doing basic "TV repair"  tube testing/swapping, what it felt like to be hit with 25KV!!! and live.   built every project Radio-shacks 75 in one had.....
then I fell in LOVE, had my heart ripped out... became a drug addict, joined the Navy for what would become the start of a 38yr successful career in electronics
quote from the 2nd Mrs.;
"I never once worried you would leave me for another woman, there is NO woman you could love more than your damned machines"
my reply;
" n that's why I married you, you understood well the benefits afforded a Concubine that chooses a life with a man like me"
relationships, goes on the "Things I failed at" side of the ledger  :icon_biggrin:
