July 26, 2026, 03:22:12 am
Hoffman Amps Forum image Author Topic: Fender Vibro-Champ w/o vibro build - OT hook up & review please  (Read 3767 times)
Offline RoadShow
  • Disturbing the Peace Since 1955
« on: December 05, 2025, 12:33:15 pm »
Hi folks,
I wanted to build a Fender Vibro-Champ w/o the vibro and "think" I've drawn the circuit correctly.  Could you please review and give me comments?
In particular, it seems the Hammond 1760C is the right fit per their website, and to match the OT to the 6V6 I would hook up the blue & red, correct?  If so, what's the proper way to tie off the 5k brown wire?  Cut it short, heat shrink the end, and tape it to the chassis?
Thanks for your inputs!!!
« Last Edit: December 05, 2025, 06:18:27 pm by RoadShow »
Offline exnihilfit
Re: Fender Vibro-Champ w/o vibro build - OT hook up & review please
« Reply #1 on: December 05, 2025, 12:40:27 pm »
why not use the Champ AA764 schematic/Layout?
https://el34world.com/charts/Schematics/files/Fender/Fender_champ_aa764_schematic.pdf
For the 5K lead on the transformer, I usually just shrink wrap the end and then loop together and use a larger shrink wrap for the rest of the lead to make it a stub, I don't like to cut in case I may use it in the future...
« Last Edit: December 05, 2025, 01:04:53 pm by exnihilfit »
Offline dogburn
  • Meddling Kid (but older)
« Reply #2 on: December 05, 2025, 01:52:59 pm »
Yep, that transformer works, but you also might consider the Hammond 1760CP, which has a 4 Ohm tap rather than 3.2 Ohm, since new 3.2 Ohm speakers aren't common (but it's a minor difference anyway).
And I put heat shrink on the end of the unused wire, roll it up and secure it with a zip tie and tuck it out of the way.
Offline dogburn
« Reply #3 on: December 05, 2025, 02:00:49 pm »
I built a no-trem Champ (the AA764, as exnihilfit pointed out), and added a NFB switch, which is a really useful mod if you are looking for additional tweaks to the circuit. I also add a mid/raw pot (from Rob Robinette's site) to give more tonal flexibility that can send the sound into more tweed territory.
Offline RoadShow
« Reply #4 on: December 05, 2025, 03:23:49 pm »
Yep, that's exactly what it is.
Offline RoadShow
« Reply #5 on: December 05, 2025, 03:41:16 pm »
1760CP, yes, but the 1760C has 8 & 16 ohm options, CP doesn't have 16.
What resistors did you use for NFB switch?  For the AB763 example he uses 820/1.5k whereas the Champ starts with 2.7k.
Offline RoadShow
« Reply #6 on: December 05, 2025, 06:19:29 pm »
Updated schematic...
Offline dogburn
« Reply #7 on: December 05, 2025, 07:25:58 pm »
I just used the standard resistor for NFB and added a switch to cut it out of the circuit. You could do a three-way switch with two different resistor values plus cutting it out, but I haven't found that as useful as a simple NFB/no NFB switch.
Offline burchyk
« Reply #8 on: December 16, 2025, 04:49:19 pm »
Not a big fan of the original 15k mid resistor, prefer 6.8k like they use on the bigger ones.
V1a cathode voltage seems order of magnitude high, should be somewhere around 1-2V.
Try 10k for V1a grid stopper, might get you lower hiss at higher volume settings.
6v6 cathode resistor: might want more than 1W power handling to run cooler, keep it away from the cap, have a few slightly higher values at hand to hit the bias sweet spot.
Filter resistors: maybe up the wattage a bit.
Consider adding rectifier diodes, and stoppers for the screen and the grid of 6v6.
Elevating heaters can help reduce the inherent hum with SE output. As easy as moving the heater center tap to the top of 6v6 cathode resistor.
« Last Edit: December 16, 2025, 05:05:13 pm by burchyk »
