September 08, 2026, 03:37:53 pm
Hoffman Amps Forum image Author Topic: Changing tone stack sanity check  (Read 10698 times)
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« on: January 07, 2026, 12:25:06 pm »
Hey guys !
This amp is getting new chassis and cab, the new chassis come with holes for a TMB tone stack !
Here the original(lil moded) schematic and the one with TMB,
 is this TMB implementation correct ?
Thanks in advance !
« Last Edit: January 10, 2026, 08:06:47 am by uki »
https://soundcloud.com/ukiuki
Offline uki
    • Uki's Guitar Trip
Re: Changing tone stack sanity check
« Reply #1 on: January 10, 2026, 09:04:17 am »
The power supply and nodes for each tubes are in place, still have to install the tremolo and tone stack,
I am unsure thou if the tone stack is correct,  anyone? Thanks !
Some more pictures.
Offline SEL49
« Reply #2 on: January 10, 2026, 09:40:11 am »
Your TMB tonestack is the same as a typical Fender AB763. Should work just fine. However, that tonestack is very lossy and may not give enough signal to drive the 6AQ5 to it's full glory without adding another gain stage. Just try it and then you'll know for sure.
If you find you need more gain, one option would be to replace V2 with a 5654/6AK5 higher gain tube. Look at lil Smoky for a known working 6AK5 circuit.
Offline uki
    • Uki's Guitar Trip
« Reply #3 on: January 10, 2026, 01:27:53 pm »
Your TMB tonestack is the same as a typical Fender AB763. Should work just fine. However, that tonestack is very lossy.....
Any suggestions for a different tone stack , that isn't so lossy ?! Thanks
Offline SEL49
« Reply #4 on: January 10, 2026, 01:55:09 pm »
My favorite is the V1 tonestack in my Dual Lite amp.
Offline uki
    • Uki's Guitar Trip
« Reply #5 on: August 13, 2026, 02:53:58 pm »
Hey guys !!
Took some time to get back to this but it is done now !!
Offline acheld
« Reply #6 on: August 14, 2026, 09:39:24 am »
Looks great!  What did you decide regarding your tone stack and what were the results?
Offline uki
    • Uki's Guitar Trip
« Reply #7 on: August 14, 2026, 11:49:04 pm »
I went with the TMB , the mid pot is 250k, the mid works as mid until mid, then it lift the TS and add some hair, got it from one of Sluckey's schematics. Also i did remove the NFB.
The amp sound really good !!
« Last Edit: August 15, 2026, 12:05:53 am by uki »
Offline ac427v
« Reply #8 on: August 15, 2026, 08:40:51 am »
That is a rockin amp! Love the trem too.
