July 25, 2026, 06:54:13 pm
Hoffman Amps Forum image Author Topic: 1970s Ampeg B-15N, screeching oscillation after recap  (Read 7984 times)
Offline cobascis
« on: February 24, 2026, 11:17:55 am »
I just picked up a very clean (entirely untouched inside) Ampeg B-15 from the early to mid 70s. I did minor testing of the amp with all the old electrolytic, but had a recording session in the next few days, so I replaced all the electrolytic and the can cap with parts from FlipTops. I also installed a 3 prong grounded cable (abraded chassis and used a large hi wattage iron to solder ground to chassis right as it enters amp), and disconnected the AC outlet and the polarity switch. I did brief testing after the recap, and the amp sounded good. It wasn't until the session that I learned all was not OK.
Here's what happens:
  • When I turn the volume past noon (with an input plugged in) a horrible oscillation/screech comes out of the speaker. The screech is fixed when I turn volume down below noon. At lower levels the amp seems to function normally.
  • The entire amp is extremely microphonic, I can tap anywhere on the chassis and it is very loud. I tried all new power and preamp tubes, no change in microphonic aspect
  • I tried another CE Can cap to see if it was a faulty cap. No improvement.
  • The screen does not occur if I pull out the preamp tubes
  • I've checked and reflowed solder on ground connections
What else should I check? Hoping it is something simple that I am overlooking, need to get this thing back in action for another recording session coming up. Happy to post voltages or anything else that might help track this down. Thanks!
Here is a video of the microphonic nature of the amp and what happens when I turn the volume up when an input is connected.
« Last Edit: February 24, 2026, 11:36:34 am by cobascis »
Offline passaloutre
Re: 1970s Ampeg B-15N, screeching oscillation after recap
« Reply #1 on: February 24, 2026, 06:35:42 pm »
Is there a specific preamp tube that kills the oscillation? Got any spares
Offline cobascis
« Reply #2 on: February 25, 2026, 07:11:13 am »
I swapped out all 3 of the GSL7 preamp tubes with known good tubes and no change to the squeal. I also tried switching the order of the preamp tubes. No dice. Put new power tubes in as well just on the off chance that was a factor, no change.
Offline passaloutre
« Reply #3 on: February 25, 2026, 07:30:53 am »
Put them one at a time. Which one kills the oscillation?
Offline cobascis
« Reply #4 on: February 25, 2026, 07:55:19 am »
Removing V1 kills the oscillation in channel one, removing V2 kills oscillation in channel 2. If V1 and V2 are removed, no oscillation in either channel. If V3 is removed and V1/V2 are left in, no oscillation.
« Reply #5 on: February 25, 2026, 08:42:26 am »
Did the amp have this issue BEFORE you replaced the caps? If not, I suggest reexamining the cap replacement with close attention to the cap that feeds the preamp tubes. Look for loose connection or poor solder on positive and negative cap terminals.
     https://el34world.com/charts/Schematics/files/Ampeg/Ampeg_B-15N.pdf
Offline cobascis
« Reply #6 on: February 25, 2026, 09:01:30 am »
I believe it did not, unfortunately I didn't spend a ton of time testing the amp before I recapped it.  But I'm fairly certain I turned it all the way up with no issues.
I've triple checked the solder on the can cap, and replaced the can cap already so I'm sure it's not the connection at the can cap itself. But perhaps where it meets the board and powers the preamp section could have a bad solder joint. Looking at the schematic, it is the middle 40uf (middle from right to left) that powers the preamp. I will see where that connections and reflow that solder. Anything else I should try?
« Reply #7 on: February 25, 2026, 09:35:10 am »
No. The 40µF on the left feeds the preamp tubes (V1 and V2).
The issue may not be directly related to the cap can replacement, but rather some collateral damage that occurred during the process
Offline cobascis
« Reply #8 on: February 25, 2026, 11:07:15 am »
Got it. Just reflowed all solder joints where the cap is providing power. Also reflowed both preamp tube socket pin 5. Checked to make sure both those resistors were at around 470K, they were. Reflowed cap can ground. No improvement so far. Hmm...
« Reply #9 on: February 26, 2026, 12:11:27 pm »
R37 supplies the preamp HT node. The symptoms align strongly with that node not being adequately decoupled, eg the 40uF cap connected to R37 either being bad or not properly connected.
It's interesting to note that the heater circuit looks to have a negative DC elevation (something would probably be needed to mitigate heater hum leaking into the signal path at the unbypassed input stage cathodes).
The standby is hot switching, its use will pointlessly stress the GZ34.
Offline cobascis
« Reply #10 on: February 26, 2026, 12:46:51 pm »
Thanks--good to know re: standby, I typically don't use standby on my amps but I will make note not to on this one in particularly.
After work I will again check, R37, R7 and R11, make sure they are measuring correctly and inspect or reflow both solder joints. Since I've tried 2 brand new can caps and done a basic capacitance check on the can cap, and reflowed and inspected the hot and ground, I don't think it could be the connection where the can cap itself connects to the amp. I reflowed where all the can cap wires terminate at the board, but perhaps a solder joint down the line from there was stressed?
Let me know if theres anything else I can physically check on when I am in there tonight. Thanks for the help everyone!
« Last Edit: February 26, 2026, 01:56:40 pm by cobascis »
Offline cobascis
« Reply #11 on: February 26, 2026, 03:54:01 pm »
I just tested resistance, removed old solder and resoldered R37, R38, R7,R11, R19,R15, and resoldered pins 2 and 5 on V1 and V2. I also touched up a few other solder joints across the board that had micro cracks. All the resistors are reasonably within spec, none open or intermittent that I can tell.
Could C3/C5, C10/C8 have anything to do with it? I haven't pulled the board up from the chassis yet, not sure if I need to. All the solder joints are visible from above, but plenty of wires routed below. I realized the only tube I haven't swapped out is the 5AR4. C17 I also replaced during the recap (replacing the large firecracker cap). I have no way to test that other than MM capacitance, which it is on spec for. With "Ultra Low" switched on, neither channel will squeal. But with it off, it will. I suspect this is just due to gain (Ultra Low is quieter usually than standard).
Would grabbing voltages help anyone further diagnose? Thanks again for the help.
« Last Edit: February 26, 2026, 04:05:51 pm by cobascis »
Offline AlNewman
« Reply #12 on: February 26, 2026, 04:56:44 pm »
Did you add any shielded cable, or is it possible you rerouted the OT lines or other signal lines?
The fuse in the top left seems a bit weird, doesn't look like factory really, and at least one of the shielded cables on the bottom right maybe looks like it's bridged?
Offline cobascis
« Reply #13 on: February 26, 2026, 05:08:33 pm »
I forgot to note--I had to replace the inline fuse. This amp has the standard exterior replaceable fuse, then an inline pigtail fuse. So you're right that it is not factory, but I replaced it in the same way it was originally wired.
I will check on the potential bridging of those shielded cables. I did not add them, or reroute any signal cables to my knowledge. I was just dealing with the can cap, power cable, fuse, and then the other electrolytics on the board.
« Reply #14 on: February 27, 2026, 07:33:05 am »
You say the issue is affected by the amount of volume you dial in. So, if you keep the volume maxed out but reduce the treble, does the issue go away? Have you got a scope handy?
Offline cobascis
« Reply #15 on: February 27, 2026, 08:03:58 am »
Just tried, turning the treble all the way down does not stop of the issue if the volume is up. I do have a scope handy.
I confirmed the shielded cable is not bridged, it looked like it was due to some flux. Cleaned that up and confirmed no continuity.
I checked some voltages, which are a bit high as expected due to my 122V AC wall voltage. That said, things are nearing the voltage rating on the can cap. I'm getting 448V DC on two of 40uf nodes to the right on the schematic, but the node that feeds the preamp tubes that connects to R37, I am getting 520V DC. The cap is only rated for 525V DC. The other PSU cap (C17) I'm getting 530V DC on the hot side (this is a 600V cap, though). This is translating to the following preamp tube voltages:
V1:
Pin 2: 215V DC (should be 175V DC)
Pin 5: 218V DC (should be 165V DC)
V2:
Pin 2: 213V DC (should be 175V DC)
« Last Edit: February 27, 2026, 09:01:07 am by cobascis »
Offline AlNewman
« Reply #16 on: February 27, 2026, 12:02:18 pm »
What are the voltages at pins 3 and 5 of the 6L6's?
Offline cobascis
« Reply #17 on: February 27, 2026, 12:22:22 pm »
Both 6L6s are at around:
Pin 3: 529 V DC (should be 450V)
Pin 5: -52V DC (can't find what it should be on schematic)
529V DC instead of 450 seems like a huge difference... should I try another 5AR4?
« Last Edit: February 27, 2026, 12:28:51 pm by cobascis »
« Reply #18 on: February 27, 2026, 01:35:32 pm »
Can you post some scope screen shots for the output and the plates of the various preamp tubes?
Offline cobascis
« Reply #19 on: February 27, 2026, 02:14:14 pm »
Sure, do you want those measurements to be while its shreiking? Or just at idle at a lower volume?
Offline BrianS
« Reply #20 on: February 27, 2026, 07:22:00 pm »
Did you change any of the grounding points from their original location(s)?  I had an Ampeg do weird stuff after I recapped it and changed one ground location.  Moved it back and the problem disappeared.
I also had to move a seemingly microphonic tube socket off the circuit board of a 1970s Ampeg.  If I remember right, the problem was quite similar to what you are experiencing.  I tried all kinds of things, but the problem seemed to be coming from the socket.  They were unusual circuit board mounted sockets.  I ended up mounting a standard socket to the chassis and running wires up to the circuit board.  This solved the problem.  Never seen anything like it.  Ampegs can be weird.
Offline cobascis
« Reply #21 on: February 27, 2026, 08:27:54 pm »
The only changes re: grounding were the addition of a grounded power cable, and the removal of the death cap which was connected to ground. The can cap remains isolated from chassis via a washer and grounded via the stock ground scheme. I will double check all grounds.
Here's how the amp looked before I did the work for reference:
Offline AlNewman
« Reply #22 on: February 27, 2026, 11:28:00 pm »
Maybe one of your power tubes isn't conducting?  The heaters are on on both tubes?  both pin 8's have a good connection to ground?  You may have to measure voltage drop across each side of your OT to find the current for both tubes.  Either that, or somehow install or temp in a couple 1R resistors between cathodes and ground.
Offline cobascis
« Reply #23 on: February 28, 2026, 04:42:24 pm »
I have a bias tester attachment for my DMM--so I can read the current on both 6L6s. Both are ~45mA. However, if I turn it up loud enough to get the squeal, they turn blue and the mA draw jumps up to double, 80+mA! Just checked pin 8 continuity to ground on both and it is <1 ohm.
Offline AlNewman
« Reply #24 on: February 28, 2026, 07:11:48 pm »
I checked some voltages, which are a bit high as expected due to my 122V AC wall voltage. That said, things are nearing the voltage rating on the can cap. I'm getting 448V DC on two of 40uf nodes to the right on the schematic, but the node that feeds the preamp tubes that connects to R37, I am getting 520V DC. The cap is only rated for 525V DC. The other PSU cap (C17) I'm getting 530V DC on the hot side (this is a 600V cap, though). This is translating to the following preamp tube voltage.
Where exactly are you getting 448V?
Offline cobascis
« Reply #25 on: February 28, 2026, 08:22:33 pm »
« Reply #26 on: February 28, 2026, 08:43:53 pm »
The cap that feeds the preamps is on left. The voltage on that cap is NOT 520V! It is 448V according to your circuit snippet.
Offline cobascis
« Reply #27 on: February 28, 2026, 09:51:28 pm »
Whoops, my mistake. You are correct (and the diagram with the voltages is correct, just double checked).
Offline cobascis
« Reply #28 on: March 01, 2026, 01:20:09 pm »
Just tried disconnecting the NFB by lifting a leg of R40 to see if that changed anything about the oscillation, no dice.
Offline AlNewman
« Reply #29 on: March 01, 2026, 05:04:33 pm »
It doesn't make much sense.  Your pre amp and PI nodes are drawing close to what they should be.  Your screens are maybe drawing 3-4mA, and they should be drawing 10mA or so for both.  But your bias meter reads 45mA/tube.  Is it possible your bias meter uses a 10R resistor, and you have to divide readings by 10?
I would suggest measuring your current across the output transformer, in this amp it's the only way to separate plate current from screen current.  Unless somebody installed a pimped out PT in your amp, or somehow you're getting a different reference to ground at chassis, you should be closer to the schematic with your B+ voltages.  I suppose with a center tap stand by, maybe the switch isn't working properly?
Other than that I would definitely double and triple check the wiring, traces, resistors, continuity, etc...
