July 28, 2026, 04:32:09 am
Hoffman Amps Forum image Author Topic: Vox AC15 based on Hoffman AC30 layout  (Read 770 times)
Offline Big_Mike
« on: July 14, 2026, 06:09:48 pm »
Hi guys,
I am gathering materials to build an AC15 from a Hoffman AC30 layout.  I get that you simply remove two of the output tubes and increase the cathode resistor, but I would like some help modifying the Hoffman layout as follows:
1.  Change from tube rectification to solid state rectification.
2.  Add in a Lar-Mar PPIMV.
Could anyone help me with modification of the Hoffman layout?   Thanks.
Offline passaloutre
Re: Vox AC15 based on Hoffman AC30 layout
« Reply #1 on: July 14, 2026, 09:05:46 pm »
Neither of those requires a change to the layout. You can put a rectifier on a couple terminal strips, and the LarMar is built on the pot.
Offline Big_Mike
« Reply #2 on: July 14, 2026, 09:31:07 pm »
I guess what I am trying to figure out is how to incorporate diodes for the solid state rectifier on the board layout.  I think I figured out the wiring points for the Lar/Mar PPIMV.  Could anyone help me with a turret board layout diagram for a solid state rectifier?
« Reply #3 on: July 15, 2026, 09:24:58 am »
If I were using Hoffman's board I would just replace the two 100Ω filament resistors with two 1N5408 diodes and make a couple minor wiring changes. Like this...
Offline Big_Mike
« Reply #4 on: July 16, 2026, 10:25:22 pm »
Thanks Sluckey, much appreciated!
Offline Big_Mike
« Reply #5 on: July 23, 2026, 04:28:54 pm »
Sluckey, to install a Lar/Mar PPIMV, I assume you remove the two 220K resistors after the phase inverter and install a dual gang 250K pot?  Thanks!
Mike
« Reply #6 on: July 23, 2026, 05:26:43 pm »
Yes . Also put a 2.2m between wiper and ground lug of each pot for safety. If you will also have a cut pot then look at page 3 of this pdf to see a neat way to install the mv...
     https://sluckeyamps.com/dual_lite/dual_lite.pdf
Offline Big_Mike
« Reply #7 on: July 23, 2026, 06:25:04 pm »
Cool, I was wondering how to incorporate a cut pot with a Lar/Mar master and plan to have it with this amp.  Thanks for the info!
Offline Big_Mike
« Reply #8 on: July 25, 2026, 08:12:59 pm »
Steve, I am looking at buying the iron for this project.  For the power transformer, I was looking at the Mojotone 18W transformer.  Does that look like a good choice?
https://mojotone.com/products/british-style-18w-power-transformer-direct-replacement-for-the-marshall-r-18w?srsltid=AfmBOordnn3HUNxre5svmSYqJLcVqUe-kNmqNgf9RtgwTUTLqt8I4JbN
I decided that I am going to stick with a tube rectifier instead of going solid state.  Let me know what you think.
« Reply #9 on: July 25, 2026, 09:15:28 pm »
The Mojotone 18W power transformer is an excellent choice. It will allow the use of a 5Y3 or EL84 rectifier. The Mojotone 18W output transformer is also an excellent choice. It has 4, 8, and 16Ω secondary taps.
Offline Big_Mike
« Reply #10 on: July 25, 2026, 10:56:05 pm »
Thanks Steve, I see Mojotone also has an AC-15 output transformer with a 6k impedance.  Any preference for that OT over the 18W OT with an 8k impedance, or is there really no difference?
« Reply #11 on: July 26, 2026, 05:53:20 am »
No preference. I've always just used an 8K OT.
