August 29, 2026, 07:18:24 am
Hoffman Amps Forum image Author Topic: Where to ground 6n2p shield?  (Read 827 times)
Offline theRagman
  • [0] days since my last soldering iron burn
« on: August 18, 2026, 12:50:45 pm »
I ended up with a pile of 6n2p-EV tubes, which I'm planning on tinkering with for my personal amp builds. Pin 9 is a shield that is supposed to be grounded, but I'm not sure what the best practice is for that. Should I ground it to the main signal ground near the input jack, or is it fine to ground it to the chassis nearby?
Re: Where to ground 6n2p shield?
« Reply #1 on: August 18, 2026, 02:04:35 pm »
I would use a ground lug connected to the mounting screw of the tube socket. Neat and short.
Offline theRagman
« Reply #2 on: August 18, 2026, 04:31:33 pm »
That sure is the answer I was hoping for! Thank you.
