August 29, 2026, 07:19:43 am
Hoffman Amps Forum image Author Topic: Question about grounding  (Read 160 times)
« on: August 25, 2026, 05:45:10 pm »
I'm thinking to a stereo guitar amp that uses two separated circuits and only one PS
I searched about how to arrange the ground sistem and what I think may be useful is to have the input jack insulated from ground and to connect the ground of the two circuits to the chassis via a pair of ground lift circuits
But if I do that I don't know how to arrange the connection of the PS negative
Will it be useful to use a pair of ground lifter also to connect the negative of the PS to the negative of each circuit ? (Before of the ground lifter that connects each circuit to the chassis)
Does someone is expert in Stereo amp (HiFi I suppose) and can help me ?
THANKS
« Last Edit: August 25, 2026, 05:53:46 pm by kagliostro »
Re: Question about grounding
« Reply #1 on: August 28, 2026, 10:49:55 am »
I've been thinking about the grounding scheme, and this is what I ended up with:
The PS ground and the circuit ground are connected to the chassis through a ground lift.
PS will be something like this
I was inspired by this:
Do you think it will be useful ?
THANKS
« Last Edit: August 28, 2026, 12:47:59 pm by kagliostro »
« Reply #2 on: August 28, 2026, 12:52:09 pm »
looks good from here, i built a SS stereo using this as a guide, didn't bother with the start-step circuit, mainly the filtering to the "right" of the PT
can't find the files, IIRC the circuit was silent as far as noise/hum goes
Offline passaloutre
« Reply #3 on: August 28, 2026, 05:45:39 pm »
I think you’re overthinking it.
All the tube stereos I’ve worked on have a shared ground between the channels.
The stereo Vibrolux I made last year has just one ground. No lift necessary.
« Reply #4 on: August 28, 2026, 08:26:23 pm »
I've no practice on stereo and so I was looking to what HiFi guys do
That thing seemed feasible to me also because I remember well that in the VOX AC30CC2 there is a Ground Lift like that Merlin suggests and the some in other recent AC15 models
« Last Edit: August 28, 2026, 08:40:38 pm by kagliostro »
