my amp seems to have verb in both channels but I don’t see how that would work in the schematic.
There is a hum when turned up and it goes away l when all the way down.
There can be some cross talk between the two channels due to the close proximity of the volume and tone wires. A little crosstalk is normal. See if the wires feeding the volume pots and returns from the tone pots run parallel and if so, separate them.
A few things to check for hum:
The early 202Rs used an open frame reverb tank with a paperboard cover mounted in the bottom of the cabinet. The later used Belton tanks contained in a pouch on the side of cabinet. Univox had a habit of grounding both tank feed and return jacks. If there is continuity between the grounds on the tank and both jacks are grounded, a ground loop is formed. If there is continuity between the grounds on the tank and both jacks are grounded, remove the ground from the tank feed jack to break the loop.
If the tank is mounted on the side of the cabinet in a pouch, make sure the tank feed is at the top of the pouch. You want to keep the tank return as far from the PT as possible.
Make sure that the tank feed wire to the jack, and the tank return wire from the jack to the pot, and from the pot to the grid of the 6AV6 do not run close to the heater wires where they can pick up hum.
