Hello,
I am trying to diagnose low clean output in my recently acquired Dynacord Twen.
It is a german guitar combo model from late 60s and is rated 17 Watts.
However with my scope I measure only a little bellow 10V into an 8 ohm load resistor before the sine signal begins to clip. This amounts to about 12 watts.
I also own another amp of this model, and in comparison the one on my bench actually has lower headroom. It starts to overdrive at around 4/10 of volume pot rotation while the other at around 7/10. Also the overdrive seems to me less pleasant. Unfortunately the other good working combo is borrowed to my friend, so i cannot currently do a side by side comparison of sound and measurements.
I bought this amp in almost original condition (other than exchanged speaker wire) and i have so far done these changes:
- installed a new 3 prong power cable
- bypassed the original multi-section cap-can and installed a set of discrete F&Ts and new dropping resistor.
- installed new pair of 6V6s
- exchanged the shared cathode resistor + bypass cap on the 6V6s - I'm using a 220r, as the original 180r biased too hot.
- tried exchanging the coupling caps between PI and output tubes (even though the originals measured quite low leakage).
When i scope throughout the amp the preamp signal seems clean, when i pull the 6V6 the outputs of the PI is also reasonable clean but whit the output tubes in, I can scope the distortion on their grids as well.
My voltages are:
B+ 341V
B+1 329V
B+2 326V
PI:
Plate: 232
Grid: 25
Cathode: 89
6V6s:
Plate: 336
Screen: 327
Cathode: 20.1
I have tried switching different EZ81 a ECC83s and also putting the original 6V6s and cathode resistor back in but with no substantial change.
Components measure close to spec.
I am looking for hints what could cause the lowered clean output and what should i check next.
Thanks for any advice!
Amp details:
https://www.smemmusic.ch/en/dynacord-twen-tube-amplifierSchematic and gut-shot attached.
