September 08, 2026, 03:37:44 pm
Hoffman Amps Forum image Author Topic: Is the ground reference for Presence the preamp or power amp?  (Read 188 times)
Offline markmalin
  • Malin Sweet Loraine
    • Malin Amplification
« on: September 04, 2026, 02:41:53 pm »
Hi, all
I'm building Robinette's 1 Watt Soldano SLO (schematic attached).  In my chassis layout I want to attach the presence control's 4k7 Ohm resistor and 0.1uf cap directly to the ground bus of either the preamp or power amp.  It's just not clear to me which is best for its reference point (ground).  My thought is the power amp's ground bus because it's close to the PI circuit.  Can someone shed some light?
Humbly,
Mark
"... there are Flying V's and then there are the ones shaped like peanuts..."  - my son at age 9
Re: Is the ground reference for Presence the preamp or power amp?
« Reply #1 on: September 04, 2026, 03:00:41 pm »
... the presence control's 4k7 Ohm resistor and 0.1uf cap ...
That, and the OT secondary common, are the 0V reference point for the power amp NFB loop.
Merlin's document on the topic is fantastic https://www.valvewizard.co.uk/Grounding.pdf
If something there doesn't make sense, many Modulus layouts show how Merlin's principles can be real world implemented https://www.mediafire.com/file/yj9xfz7l2wx1dc8/DF_Mrs_Layout.pdf/file
« Last Edit: September 04, 2026, 03:05:11 pm by pdf64 »
