September 21, 2026, 11:21:19 am
Hoffman Amps Forum image Author Topic: Mac users print problem w/ DIYLC  (Read 501 times)
Offline jyrki3101
« on: September 20, 2026, 12:40:34 am »
Hi, I create layouts with DIYLC on Mac mini M4 and only printer available is my Dad's one with his Intel iMac ! I cannot print a layout which is created on my newer updated version cause on my Dad's iMac has an older version od diylc. I changed diy file to pdf and tried to print that on Dad's printer but that didn't work either.
I would appreciate any kind of help cause it would be so convenient to just place the printed layout w/out components on the FR4 board start drilling.
Offline Rontone
  • Ixnay on the Ampscray
Re: Mac users print problem w/ DIYLC
« Reply #1 on: September 20, 2026, 06:18:35 am »
I've never used DIYLC on my Mac, I'm wondering why the pdf did not print? On my PC the layout pdf files to seem to load the components individually as if it is layered?
Is there an option in the pdf software for you to convert the pdf to a jpeg or similar and it may work then
« Reply #2 on: September 20, 2026, 08:03:39 am »
Do not create multiple post for the same issue
I deleted your other post
Offline acheld
« Reply #3 on: September 20, 2026, 09:44:48 am »
I use DIYLC exclusively on Mac, both with Intel based Mac mini and Apple silicon based Mac mini.   Printing works, though not always the most convenient, and you won't have as much control over printing as you would like.
Are you saying that you can't connect to your Dad's printer?   If so, print to pdf and then print the pdf file on your dad's computer.  Maybe email the file to him.
Not clear on the details here.
