October 01, 2026, 04:19:28 pm
Hoffman Amps Forum image Author Topic: GA5 Build Question - 6.3V to 5.0V Dropping Circuit  (Read 416 times)
Offline ALK2MT
« on: September 28, 2026, 09:37:58 pm »
Hi there. I’m working through the last few circuit checks before putting tubes in a GA5 scratch build and have a question/observation. In the circuit I am using a 5Y3 tube in V3 and an Antek AS-05T320 toroidal power transformer with 2 separate 6.3VAC supplies. I built a voltage dropping resistor circuit that is connected in series on the blue/green secondary 6.3V supply to drop 1.3V and safely provide 5.0 V to V3-2,8.
I used two 0.34 Ohm 10 Watt wirewound resistors, wired in series for a total of 0.68 Ohms. My tests show it is performing at spec 0.68Ohms. The voltage however is showing 6.7V at V3-2,8. So there has not been a voltage drop through the resistors.
Ideas? Thoughts? Coaching?
Thank you.
Offline roarshock
Re: GA5 Build Question - 6.3V to 5.0V Dropping Circuit
« Reply #1 on: September 28, 2026, 09:57:25 pm »
I'm no wizard, but if the resistors aren't dropping I gotta ask, were the tubes in the circuit? There won't be voltage drop if there's nothing drawing.
Offline Kaptinkangaru
« Reply #2 on: September 28, 2026, 10:16:48 pm »
Are you testing under load?
Offline ALK2MT
« Reply #3 on: September 28, 2026, 10:19:48 pm »
Tube in, 5.01Volts. Works great!
