September 13, 2026, 06:58:56 am
Hoffman Amps Forum image Author Topic: Typical drill bit sizes  (Read 8360 times)
Offline Fresh_Start
  • noob de Lux
« on: July 28, 2008, 09:21:48 pm »
Do you all think it would be useful to compile a table of drill sizes for various tasks?
For example:
Turret (standard) 3/32"
Eyelet 1/8"
Input jack - 3/8"
Isolated input jack - 1/2"
Test point jack 1/4"
Toggle switch (large) - 15/32"
#8 bolt
#6 bolt
etcetera
Or is this something everyone should figure out on their own if they don't know it instinctively?
My question has nothing to do with having to re-drill several holes and use one size smaller bolt than planned in a chassis last weekend... at least I didn't remove too much metal on the first pass ;)
Chip
Quote from: jjasilli
Quote from: PRR
Re: Typical drill bit sizes
« Reply #1 on: July 28, 2008, 09:53:41 pm »
I don't know about garolite boards; but Goug's el34 world has info on drill bit sizes for that.  For everything else I use z 1/8" bit for a pilot hole; then a unibit.
Offline sawdust
  • tube amps are cool
« Reply #2 on: July 29, 2008, 05:59:50 am »
I believe this may be every drill bit chart ever published.
Google "drill bit chart"
« Last Edit: July 29, 2008, 11:34:14 pm by PRR »
Dave in Dacula
Offline tubesornothing
« Reply #3 on: July 29, 2008, 09:08:27 am »
Here is mine.  I post it right by the drill press.
Tube socket screws   #4   1/8”
Power Tube Belton tube socket holes      ¾”
Preamp Tube holes      7/8”
Board screws   #4   1/8”
Transformers   #8   3/16
OT tx grommets      ½”   0.5
PT tx grommets      7/8”   0.875
Rev tx grommets      ½”   0.5
Jack isolated      ½”   0.50
Jack grounded      3/8”   0.375
Pot      5/16”   0.3125
Fuse      ½”   0.5
Standby/power switch      ½”   0.5
Carling switch      ½”   0.5
Taiwan Indicator      0.40”  (10mm)   0.40
Fender lamp assembly      11/16”   0.6875”
Small switch      ¼”   0.25
Impedance switch      13/32   0.40625
Belton 9pin solder tab      ¾”
Belton 8pin solder tab      1 ¼”
Speaker mount hole      15/64   .2344
Handle mount hole      15/64   .2344
Offline Fresh_Start
  • noob de Lux
« Reply #4 on: July 29, 2008, 02:48:14 pm »
t-o-n
That's what I was thinking of!
http://images.google.com/images?sourceid=navclient&ie=UTF-8&rlz=1T4GZHZ_enUS226US226&q=drill+bit+chart&um=1&sa=X&oi=image_result_group&resnum=1&ct=title
Dave - those links go some strange places...
Chip
« Last Edit: July 29, 2008, 02:50:34 pm by Fresh_Start »
Quote from: PRR
