September 23, 2026, 02:02:42 am
Hoffman Amps Forum image Author Topic: Lightbulb Current Limiter is where...  (Read 8198 times)
Offline mrmjp
« on: February 07, 2009, 01:45:41 am »
Ok, I give up, the links that I found in the forum don't work anymore since it has moved. Anyone have a How to build a Light bulb current limiter for Nubies?
Offline Geezer
Re: Lightbulb Current Limiter is where...
« Reply #1 on: February 07, 2009, 06:45:17 am »
Here's the drawing>>>
Offline Greasehorse
  • Tube Amp Amateur
« Reply #2 on: February 25, 2009, 08:04:59 pm »
I built one in a plastic twin receptacle electrical box with two receptacles and used a light bulb adapter to plug into the receptacle light bulb connects the proper wires..
Not observing amp safety can kill you!
Offline Greasehorse
  • Tube Amp Amateur
« Reply #3 on: April 16, 2009, 06:35:56 am »
Make sure not to use Romex for the wire to the AC as it will give you trouble with the light standing up on it's own. Use a flexible power cord.
Offline AZJimC
  • What a pretty glow!
« Reply #4 on: April 16, 2009, 04:15:43 pm »
I used one of those metal outdoor boxes, with a light bulb socket sold for an outdoor flood light, so it screws into the half inch pipe thread holes on the box, keeps wires neat, and the bulb is adjustable in how it stands.
Offline LooseChange
    • Fix Your Darn Amps
« Reply #5 on: April 16, 2009, 04:40:23 pm »
I think someone should post this once per month... Remind all the fuse blowers that there is a better way!
Call me Dan
www.fydamps.com
Offline RicharD
    • Toxic Water
« Reply #6 on: April 16, 2009, 09:01:46 pm »
Do you know what blows fuses?
Queer electrons.........
Offline Fresh_Start
  • noob de Lux
« Reply #7 on: April 18, 2009, 08:08:16 am »
For once I am truly laughing out loud!  ;D
Of course, you'll burn in hell for that outburst of insensitive, neocon nonsense... ;)
Chip
Quote from: jjasilli
Quote from: PRR
