September 22, 2026, 12:43:53 pm
Hoffman Amps Forum image Author Topic: LED's...How to calculate the dropping resistor  (Read 5354 times)
Offline Geezer
« on: March 03, 2009, 03:35:01 am »
This is a handy picture showing the formula for calculating the required voltage dropping resistor for a known value/rating LED.
If I don't know the LED's rating, I usually just hook up a 5k-25k pot in-line as a variable resistor, adjust it to an acceptable brightness, then measure the pot & replace it with the next closest higher value resistor.
When you buy a LED, it will have a voltage and current rating. Typical values you might see at Radio Shack would be 2 volts at 20ma. This pic will show you how to calculate for any LED. The calculated resistance will give you the maximum brightness for a particular LED. I would not go below that value, but it's fine to go above. The higher the resistance, the dimmer the LED. And of course, you'll reach a point where the LED stops emitting light.
So, like TubeGeek said, it's not too critical.
