September 22, 2026, 08:48:11 pm
Hoffman Amps Forum image Author Topic: Which is better?  (Read 6669 times)
Offline roadhog96
Which is better?
« on: March 09, 2009, 11:33:19 am »
After searching what seems to be forever for a replacement 8-pin tube socket for my vintage blackface Fender amp I was unable to find a replacement that matches the originals exactly. I found one that was made out of the original material which I believe was Phenolic, sometimes referred to as Bakelite, but the metal mounting flange was shaped different and the pin holes had different style holes. I also found one that matches the original style almost perfect, same style metal mounting flange, pin hole shaped the same as the originals, but was made out of ceramic. Both of these were advertised as being an exact replacement for this amp with the same dimensions and required chassis hole. Now I know either one would do the job, but seeing how neither one is an exact replacement, maybe it would be better to use the one that offers the best performance overall. Anyone have any thoughts on which one is the better of the two, Ceramic or Phenolic?
« Last Edit: March 09, 2009, 01:15:15 pm by roadhog96 »
Offline tubesornothing
Re: Which is better?
« Reply #1 on: March 09, 2009, 04:20:53 pm »
I find that with some cheap ceramics, the pins don't hold the tube that well.  I sure like belton sockets.
Offline roadhog96
« Reply #2 on: March 09, 2009, 07:49:54 pm »
Are these the cheap ceramic ones your refering to?
Offline billcreller
  • 1934
« Reply #3 on: March 10, 2009, 09:58:08 pm »
Those are Doug's, and I have found them to work great.
Offline roadhog96
« Reply #4 on: March 11, 2009, 04:19:15 pm »
How much personal experience have you had with these on your own amp or amps? Do they hold up well over time. Does the heat effect the pins? Any problems at all?
