September 23, 2026, 12:22:33 am
Hoffman Amps Forum image Author Topic: OT - need to ID tool  (Read 6090 times)
Offline jrmintz
    • sethglassman.com
« on: March 24, 2009, 05:02:11 pm »
Hi All,
Attached is a picture of the mini jack on a pair of Fostex T20 headphones. I had to fix a pair the other day, and I couldn't figure out how to get this nut off. It has two grooves, one on each side. I tried needle nose pliers and it was clear I'd ruin the nut. What tool do you use for this kind of nut?
Seth
Offline G._Hoffman
Re: OT - need to ID tool
« Reply #1 on: March 24, 2009, 05:29:14 pm »
You need a pin spanner.  You can likely get the right size for that one at your local bicycle shop, though it might be too small.  You might also try McMaster-Carr, of course.
Gabriel
Offline jrmintz
    • sethglassman.com
« Reply #2 on: March 24, 2009, 06:55:32 pm »
Thank you!
Offline punkykatt
« Reply #3 on: March 24, 2009, 07:32:23 pm »
I usually make a tool for a job like that. I never throw anything away, so I have all kinds things i can make usefull.  I would make a tool for that nut using a piece of metal flat stock the thickness of the slots on that nut. Using my bench grinder ,  dremel grinder, and a file, notch out two ears to fit the nut. Use a pair of plyers to turn the make shift tool and your home free.  Good luck  Punky 8)
Offline dBDoctor
  • why does my amp smell like a toaster... uh oh!
« Reply #4 on: April 02, 2009, 04:05:07 pm »
or maybe a wide flat screwdriver...
