September 20, 2026, 11:10:37 pm
Hoffman Amps Forum image Author Topic: LED orientation  (Read 15066 times)
Offline rzenc
  • TUBES RULE
LED orientation
« on: April 24, 2009, 01:49:17 pm »
Hi....smoked-mind question... :D
The LED has 2 legs...one bigger than the other...which one should I connect to ground??? I.m trying to install a relay based distortion...actually the *umble OD stage...
Thanks in advance
Best Regards
Rzenc
Offline Iannone
  • If it's too loud, you're too old
Re: LED orientation
« Reply #1 on: April 24, 2009, 02:41:21 pm »
The shorter lead is the cathode, and that one goes to ground (or the lower voltage connection) in a DC circuit.
Offline rzenc
  • TUBES RULE
Re: LED orientation
« Reply #2 on: April 24, 2009, 02:52:17 pm »
THANKS!!!!!!!!!!!!!!!!!!!!!!!
BEST REGARDS
RZENC
