September 20, 2026, 07:06:17 pm
Hoffman Amps Forum image Author Topic: Power a 3V laser from from 5VDC  (Read 12225 times)
Offline tubesornothing
« on: May 26, 2009, 06:28:31 pm »
Got a little 3V laser I wanna hook up, but all I got is 5VDC regulated.  Do I have to use a regulator or can I just calc the current and use a resistor?  The laser supposedly has some kind of automatic power control - thats probably output power though...
If I was going to use a resistor, I need a 2V drop.  The laser takes 20mA.  R = V/I = 2/.02 = 100R   - sound about right?
thanks
ToN
« Last Edit: May 26, 2009, 06:34:12 pm by tubesornothing »
Re: Power a 3V laser from from 5VDC
« Reply #1 on: May 26, 2009, 08:23:01 pm »
Where did you find a "3V laser"?
Do you have a link?
« Reply #2 on: May 26, 2009, 08:30:02 pm »
Sure, no data sheet, but this is it:
http://www.apinex.com/ret2/lmcan.html
« Reply #3 on: May 26, 2009, 08:45:49 pm »
Nobody has a clear data-sheet for this general class of lasers (brass tube, 2-wire, under $50).
Some of the higher-price modules specify "5V +/-1%", an incredibly tight spec. Especially since we know the cheaper ones are sometimes powered with two batteries.
I just can't help. For $2, I'd guess, but for $35, I don't want to risk it.
« Reply #4 on: May 27, 2009, 09:09:26 am »
Good enough for me - thanks.  I will use a regulator.
