August 27, 2026, 08:32:49 pm
Hoffman Amps Forum image Author Topic: Genz Benz 15 speaker  (Read 9410 times)
Offline duke of earl
  • Bird is the Word
« on: June 21, 2009, 08:56:58 pm »
A friend gave me a brand new in the box Genz-Benz 15 inch ceramic speaker made by Eminence yesterday. I have no idea what this speaker was designed for. It has no watt rating on it, only 4 ohms and it is very light for a 15. Anyone ever hear these speakers and if so are they practical for guitar?
Offline Frankenamp
  • What does this button do?
Re: Genz Benz 15 speaker
« Reply #1 on: June 22, 2009, 09:51:11 am »
From what I know, G/B caters mostly to bass guitar. See if one of your friends has a 'woofer tester' and  check the Thiel-Small parameters. That is the only way short of using a full-blown speaker measurement system like Sound-Easy CLIO or LMS.
This problem calls for a bigger hammer!
Offline Shrapnel
« Reply #2 on: June 22, 2009, 12:49:34 pm »
I've seen Genz Benz guitar amps... those are pretty much high-gain hybrid type things (read: not all tube, SS in the signal path)
as far as the speaker, IDK.
-Later!
Offline Frankenamp
« Reply #3 on: June 23, 2009, 02:11:09 am »
solid state = power to burn ~> low efficiency speaker
Offline Shrapnel
« Reply #4 on: June 23, 2009, 03:18:20 am »
I *think* the SS was in the preamp, and not the power amp...  (Also thought I had some Schems for one, but nope, just some for Hughes & Kettner)
Their El Diablo 100
• Two Independent Tube Channels
• Six Triode Preamp Stages (3-12AX7 Tubes)
• Four Power Tubes (ships w/Ruby Tube EL 34's)
• EL34 or 6L6 Power Tube Capability
• Rear Panel Bias Pot
lit. even says 5881s (guess using 6L6 settings)
Black Pearl is meticulously designed with an all-tube signal path
• Class A, EL 84 Power Tubes
• All-Tube Signal Path
• Flexible Power Selections-Pentode/Triode Selector 30 Watts/15 Watts/8 Watts
• Tube Boost Preamp Stage (Footswitchable)
• Tube-Driven Reverb
• Tube Rectifier
"Class A EL84" outputs on that Black Pearl sound like the marketing team at work again... based off someone's LACK of knowledge on self-baised tubes, or someone's lack of understanding when it was  told to them.
Lookin at their site, they cover Bass, Acoustic, and Guitar... it's apparently a Kaman brand.
Bass & Acoustic look to be all SS.
Also can't find any of their 15" speakers rated 4-Ohm (unless it has more than one speaker in a cab.)
-Later!
