August 11, 2026, 11:10:17 pm
Hoffman Amps Forum image Author Topic: Weber Bias-Rite "expectations"?  (Read 5325 times)
Offline FiddlinJim
  • Teles, fiddles, tweeds
« on: July 31, 2009, 03:08:09 pm »
Gang,
I bought a single octal bias-rite head with the plate voltage / cathode current switch a while ago. I'm plugging it in to a pretty cheap DMM and getting strange results. The cathode current looks "right" (or is that "rite"?) but the plate voltage looks divided by 10. So, if I'm expecting like 375 Volts, it's showing 37 or 38. Is this a defective Bias Rite or a DMM incompatibility? I've written a couple of email questions to Ted, but haven't gotten a response. I know he's busy and has some pretty enormous health problems, so I haven't wanted to bug him. Any experiences or insight anybody?
Offline jhadhar65
  • The whole thing stinks like yesterdays diapers!
Re: Weber Bias-Rite "expectations"?
« Reply #1 on: July 31, 2009, 03:31:47 pm »
According to his website, it should be a 10,000:1 ratio, so Va=375V should read 0.037.  The plate resistor that develops the drop for the plate voltage reading should be 1M.  What is yours?
He's got some pretty hefty spam filters at work over there, so you might try posting to his attention at his kit forum:
http://www.weberorders.com/forum/index.php
Offline FiddlinJim
« Reply #2 on: July 31, 2009, 03:43:53 pm »
Thanks. I thought the drop was only for cathode current:
"If you purchased the Bias Rite head only, set your voltmeter to read the lowest volts range. Then, the meter will read directly in milliamps. For instance, when your meter reads 35 millivolts (.035 volts), it is indicating 35 milliamps of cathode current."
I assumed that the plate voltage would be straight through. I'll see if I can measure the resistance of the probe's pins tonight.
Offline jhadhar65
« Reply #3 on: July 31, 2009, 05:19:15 pm »
No, he's got it engineered so you don't have to switch meter scales to get plate voltage - just the Bias-Rite switch.  That might be your issue right there.
