August 12, 2026, 10:06:52 am
Hoffman Amps Forum image Author Topic: Dumb Terminology Question  (Read 5554 times)
Offline Fresh_Start
  • noob de Lux
« on: September 08, 2009, 01:58:33 pm »
I want to connect the "sync" output of my signal generator to the "Trigger" input of my oscilloscope.  The signal generator has two jacks for bannana plugs.  What do you call the connector type on the oscilloscope?  The jack is just like the jacks for the probes.  You push on and twist.
I need to know so that I can order (or make) a cable.  Any good ideas on sources for a ready-to-use cable?
Thanks in advance for your help.
Chip
Quote from: jjasilli
Quote from: PRR
Offline jhadhar65
  • The whole thing stinks like yesterdays diapers!
Re: Dumb Terminology Question
« Reply #1 on: September 08, 2009, 02:45:54 pm »
It's a BNC connector.
Can't help on the ready-made cable source, though.
« Reply #2 on: September 08, 2009, 02:55:39 pm »
Don't make a special cable. Just get several of these Pomona 1269 adapters and use all BNC cables.
Offline Fresh_Start
  • noob de Lux
« Reply #3 on: September 08, 2009, 05:07:52 pm »
You are most excellent dudes!
Steve, with a manufacturer and a part number, even I can find the darned thing.  :wink:
Cheers,
Chip
Quote from: PRR
« Reply #4 on: September 08, 2009, 08:44:47 pm »
Here's another adapter you will find useful for guitar amp work.
http://www.pomonaelectronics.com/pdf/d1297_1_01.pdf
