August 12, 2026, 10:10:14 am
Hoffman Amps Forum image Author Topic: tube?? kt66  (Read 5818 times)
Offline mark_enger
tube?? kt66
« on: September 09, 2009, 03:50:06 pm »
  does a kt66 wire up and work the same as a 6l6gc im waining to use 6l6 instead of kt66 in my jtm45 project can i wire up socket and circuit the same using 6l6 instead of kt66?  mark
Offline Dynaflow
  • Have a cow man!
Re: tube?? kt66
« Reply #1 on: September 09, 2009, 05:39:32 pm »
 Its the same, the only different one is a el34 which I believe has to tie pin one and eight together. The kt66 and 6l6 are for all intents and purpose the same thing.
Regards,
Dyna
Ps: The jtm45 is really just a bassman, if you want to see if there are any changes, look for a tweed bassman schematic or layout as they used 6l6's.
Offline andrew_k
Re: tube?? kt66
« Reply #2 on: September 09, 2009, 07:07:42 pm »
Other than KT66 requiring more than 1.5 times the heater current of 6L6.
Offline Dynaflow
  • Have a cow man!
Re: tube?? kt66
« Reply #3 on: September 09, 2009, 07:37:25 pm »
 Well yeah, there is that...  :smiley: Not a problem if he planned for 6l6's though...
Regards,
Dyna
Offline mark_enger
Re: tube?? kt66
« Reply #4 on: September 09, 2009, 08:36:51 pm »
thanks ill build on then, the pt im gonna use i measurred at 540 plate voltage with just the recto tube in it so i can exspect hi plate voltage and will need a little bigger dropping resistors this should be an adventure but ive gotta try something new   mark
« Last Edit: September 09, 2009, 09:07:51 pm by mark_enger »
