August 12, 2026, 12:08:12 pm
Hoffman Amps Forum image Author Topic: When to use external trigger on oscilloscope?  (Read 19572 times)
Offline Fresh_Start
  • noob de Lux
« on: September 10, 2009, 02:39:35 pm »
Oscilloscope (2 channel) - check
O'scope probes - check
Signal generator - check
Split bannana plug to alligator clip cable - check
So far, I've clipped the signal generator cable to a bare 1/4" plug to serve as input to the amp and then attached oscilloscope probes to two points in the circuit for comparison to "see" what is happening between them.  Set on "Auto", the o'scope uses the channel 1 input as its "trigger" (I think).
So when would I need to use the external trigger input on the o'scope?
I'm thinking that it doesn't matter if the signal generator is attached to the input jack.  Is the trigger useful when the signal generator is attached further along the circuit but still before the o'scope probes?  If so, how?  Are there other circumstances where using the external trigger is useful?  (detecting phase shifts is my only guess so far)
Bottom line, I was thinking that I should buy a cable for the external trigger but maybe that's not necessary...
I did check the oscilloscope links in the References thread but those didn't help with this question.
While I'm at it, does Kobican make good cables? (specifically part #172-2129-EX)
Thanks in advance for your help.
Chip
Quote from: jjasilli
Quote from: PRR
Offline tubesornothing
Re: When to use external trigger on oscilloscope?
« Reply #1 on: September 10, 2009, 02:59:42 pm »
Congratulations on the scope!
Dont bother with external trigger. 99% of your scope will trigger off the input.  It really is only useful with very low amplitude stuff.  E.g. looking at very small ripple in a power supply, you can external trigger off the mains.
Are your probes 1x 10x switchable?
Can't wait to see some pics!
« Reply #2 on: September 10, 2009, 08:57:56 pm »
In audio? With good modern self-triggering? Practically never.
In complex logic, rare event A should cause B. You watch B while triggered with A so you see what's happening or not-happening.
Offline Fresh_Start
  • noob de Lux
« Reply #3 on: September 11, 2009, 12:59:23 am »
OK cool.  One less thing to worry about!
Chip
Quote from: PRR
« Reply #4 on: September 11, 2009, 06:50:55 am »
Which scope do you have? For most scopes "Auto" refers to automatic trigger 'level', not trigger source.
You're not likely to ever need the EXT trig if all you ever look at is sine, triangle, or square waves. All those signals are repetitious and easily triggerable using the vertical input as a trigger source.
Here's the setup I always use when using a sine wave sig gen, scope, and amp. Put a Tee connector on the sig gen output. Connect one cable between the Tee and scope channel 1. Trigger the scope on channel 1. Connect another cable between the Tee and the amp input (or injection point). Doing this allows you to always see your input signal. Comes in handy if you want to change signal level or frequency.
Now connect your scope probe to scope channel 2. Set the vertical mode to "alternate". Now you can see your input signal and the signal with the probe as you examine different points along the amps signal path. You readily see the gain, loss, phase shift, distortion, etc., and can quickly compare to the input signal. Since you're triggering on the input signal on channel 1, you don't have to readjust trigger levels as you move the probe around. (I know that using "Auto" triggering usually means you don't have to be readjusting trigger levels, but in my line of work I often need to have complete control over trigger levels and slope, so I mostly use "Normal" triggering and diddle the level and slope as needed)
I have a couple sig gens, one has a sync output, the other does not. When I use the sig gen with the sync output, I connect that sync output to the scope EXT TRIG input, select EXT TRIG source, NORMAL TRIG mode, and use the manual trig level. My sig gen sync output is a constant level (ie, does not change with sig gen output attenuator) square wave that's ideal for scope triggering.
I'm not familiar with that brand, but I would not be too concerned about BNC cable quality for guitar amp work, unless they look really cheezy!  I would recommend getting 6 each 6' BNC cables, 2 each probes 1X and 10X, and a double handful of various adapters, TEEs, barrels, etc.
« Last Edit: September 11, 2009, 06:54:25 am by sluckey »
Offline Fresh_Start
  • noob de Lux
« Reply #5 on: September 11, 2009, 07:15:40 am »
Thanks again!
Chip
Quote from: PRR
« Reply #6 on: September 11, 2009, 09:19:48 am »
Nice!
Offline Fresh_Start
  • noob de Lux
« Reply #7 on: September 11, 2009, 03:16:37 pm »
Nice!
Beats the heck out of trying to clip the o-scope probe onto the grid of V1A without shorting to the plate (not that I've ever done that... )
Thanks again Steve!
Chip
Quote from: PRR
