September 08, 2026, 11:27:41 am
Hoffman Amps Forum image Author Topic: BF Princeton w/o Trem or Reverb  (Read 11772 times)
Offline Fresh_Start
  • noob de Lux
« on: September 13, 2009, 09:07:50 am »
Someone on the Ampage forum asked about a non-Reverb Princeton with a switchable gain stage to simulate the AA1164 circuit.  Here's what I came up with as a first cut.
Please let me know if the 470K resistor to ground on the grid of the V2a is necessary.  It looks like the lower leg of a voltage divider with the 3.3meg in the AA1164 circuit.
This should be a nice, simple amp to build.  A 6BM8 version would only need 4 tubes total and might be really cool.
I have NOT built this amp.
Chip
Quote from: jjasilli
Quote from: PRR
Offline LooseChange
    • Fix Your Darn Amps
Re: BF Princeton w/o Trem or Reverb
« Reply #1 on: September 13, 2009, 09:24:38 am »
My logic says.. YES.
You should try a boost function that lifts the tonestack ground.  Add a switch and limit the lift with a resistor (around 50k works well). Or use a pot and a switch and provide a variable boost.
Call me Dan
www.fydamps.com
Offline Fresh_Start
  • noob de Lux
« Reply #2 on: September 14, 2009, 12:27:00 pm »
The 25K audio taper Mid pot was intended to go in that general direction.  However, I really want to try your "Girth" control someday soon.
Frankly, I think this circuit would be too clean without the bypass cap engaged on the second triode.
Chip
Quote from: PRR
