September 17, 2026, 05:15:05 am
Hoffman Amps Forum image Author Topic: Victor Animatograph speaker  (Read 12716 times)
Offline jrmintz
    • sethglassman.com
« on: October 03, 2009, 10:23:35 am »
Hi,
I picked this cabinet up at a yard sale for $20.00. I don't know how to figure out if the field coil and speaker are working. Is there any 'vintage charm' to this speaker if it is working or should I just toss it and put a modern speaker in the cabinet?
Seth
Offline snoof
Re: Victor Animatograph speaker
« Reply #1 on: October 05, 2009, 07:33:42 pm »
that transformer could be the OT for the amp?  hard to tell from the pics.  could just be a reg alnico speaker.
Offline Dynaflow
  • Have a cow man!
« Reply #2 on: October 06, 2009, 01:54:42 am »
 Not sure either, aren't these just a cabinet that went with a 16mm projector?
Regards,
Dyna
Ps: It won't hurt a thing to box that stuff up and put a regular speaker in there. Heck it is a cool looking little cab.
Offline jrmintz
    • sethglassman.com
« Reply #3 on: October 06, 2009, 08:12:43 am »
Thanks.
Yes, it went with a Victor projector. It's the grill that caught my attention - I think it's a pretty cool looking cabinet.
Offline stingray_65
« Reply #4 on: October 18, 2009, 07:36:12 pm »
I am NO AUTHORITY on field coil speakers
I'm looking at a field coil speaker on my bench and it has 4 terminals
2 for the magnet coil and 2 for the voice coil
or so i think :)
Offline Frankenamp
  • What does this button do?
« Reply #5 on: October 21, 2009, 09:54:55 am »
It's hard to tell from the angle of the bottom photo. If you can post one that is about 30 degrees lower than the bottom photo- so we can see the lower portion of the speaker (the connection area) more clearly. However Stingray65 is correct: 4 connections would definatly be a field coil speaker. I've seen a few that use a common chassis connection (and those are totally unsafe). The general 'look'  says PM driver- but I could be wrong.
This problem calls for a bigger hammer!
Offline jrmintz
    • sethglassman.com
« Reply #6 on: October 22, 2009, 02:01:58 pm »
Here's some pictures of the transformer and attachment points. How can I tell if it would be usable in a guitar amp context? How can I tell the impedance?
Offline Frankenamp
« Reply #7 on: October 24, 2009, 10:52:44 pm »
So far, it still looks like a PM speaker. I'm curious as to the connections on the other end of the cable. It looks like a pretty non-standard wiring job to me. I think that that round plug with the pin will change impedance, and the two connector socket that looks like a power plug is actually for an extension speaker. Maybe PRR has seen it's like before. It's definatly non-standard and non-safe.  To check impedance, just unhook the transformer, and put a meter across the terminals. multiply the number by 1.414 ie. 3.2 is 4 ohms, 5 or 6 ohms is about 8 ohms, and 12 ohms DC is about 16 ohms AC. This will give you a 'ballpark' figure. all speakers have a impedance curve that varies from DC resistance to somewhere between 20 and a hundred ohms. (that all depends on the voice coil suspension stiffness and strength of the gauss in the magnetic gap)
Offline jrmintz
    • sethglassman.com
« Reply #8 on: October 25, 2009, 09:44:56 am »
Frankenamp, I don't know what you mean by a "PM" speaker.
Thanks for all the information,
Seth
Offline Dynaflow
  • Have a cow man!
« Reply #9 on: October 25, 2009, 05:21:02 pm »
 I think he means Permanent Magnet...
Regards,
Dyna
Offline Frankenamp
« Reply #10 on: October 25, 2009, 07:01:56 pm »
Sorry,  PM is audiospeak for a Permenant Magnet. could be alnico, ceramic or neodymium... just a generic class division like white or brown bread. +1 Dynaflow! (was hoping that one of the old-timers would chime in... I'm sure they had those to show movies on the Ark...) :wink:
Offline Dynaflow
  • Have a cow man!
« Reply #11 on: October 25, 2009, 08:57:13 pm »
 :laugh: Yeah, the ark had movies.. The in voyage food was a bit rough, the animals would get annoyed at the thought of a bbq..  :smiley:
Regards,
Dyna
Offline jrmintz
    • sethglassman.com
« Reply #12 on: October 25, 2009, 09:55:27 pm »
Thanks everyone. The speaker is 8 ohms, and it works great. The cool thing is, aside from the grill, is that the back comes off. It can be open back or closed.
