August 14, 2026, 06:42:59 am
Hoffman Amps Forum image Author Topic: Tube amp related Xmas gifts: Score or FAIL?  (Read 6803 times)
Offline The_Gaz
« on: December 25, 2009, 10:49:37 pm »
My Dad picked this old Kester up for me at a military surplus store on the cheap. It's marked:
    - 60 Sn (which I think implies 40 Pb)
    - .40 diameter
    - W.S.  Water Soluble???
    - QQ-S-571e. I think this is military grade solder, but that's all the info I could find.
So will this stuff give me the tone??? :rolleyes: No, just kidding. But seriously, can I stick some leads to turrets with this stuff?
Anyone score (or fail) with a tube related gift from a non-tube relative?
Re: Tube amp related Xmas gifts: Score or FAIL?
« Reply #1 on: December 26, 2009, 03:12:04 pm »
Surely not .40 diameter? That's too fat for tin roofs!
Offline The_Gaz
« Reply #2 on: December 26, 2009, 06:14:29 pm »
 :embarrassed: .040 diameter.
Offline The_Gaz
« Reply #3 on: December 26, 2009, 06:20:38 pm »
This stuff.
« Reply #4 on: December 27, 2009, 12:23:17 am »
It's fine solder. But in electronics it is very much more convenient to use flux-core solder. I'm not sure how you'd use that stuff.
Offline The_Gaz
« Reply #5 on: December 27, 2009, 12:33:32 am »
oh, crap.
Offline imaradiostar
« Reply #6 on: December 30, 2009, 07:51:33 am »
You could get a little tin of flux and dip it before adding solder to joints. When I was a kid I used to use a little brush and lightly (or not so lightly) cover components in flux to compensate for my mediocre soldering skills. I managed to make things stick this way...
I've used similar solder without too many bad results. If things continue in this lead-free solder direction that roll is likely to become more valuable!
jamie
Offline The_Gaz
« Reply #7 on: December 30, 2009, 12:06:00 pm »
Thanks for the tip, my sis recommended the same. I was actually able to trade it for some 60/40, 282 flux, 58 core stuff. it's very fat - .09 or something. I figured I could use it for soldering to big terminals, pots (probably guitar only), or making test tools. Thanks again.
