August 29, 2026, 08:48:39 am
Hoffman Amps Forum image Author Topic: Standby switch needed? (Placement)  (Read 12878 times)
Offline chip
« on: April 10, 2010, 05:25:25 pm »
This is my first try at a solid state rectifier amp.  Just a few questions on the standby switch:
Push Pull,   2X6L6GC,   4X12AX7,   Fixed Bias
1)   Do I really need a standby switch for this amp?
2)   If I do need a standby switch, is this location a good one?
3)   If I put the standby switch in the location shown does it have to be rated for at least 500-700V?
4)   Where can I find a switch that is rated for this high a voltage?
Offline tubesornothing
Re: Standby switch needed? (Placement)
« Reply #1 on: April 10, 2010, 05:36:21 pm »
A whole article on standby and power switches:
http://www.freewebs.com/valvewizard1/standby.html
Offline JayB
« Reply #2 on: April 10, 2010, 05:48:45 pm »
I prefer the switching before the diodes. Safer that way.
You're going to hell faster than Britney Spears running to a Barber shop
« Reply #3 on: April 11, 2010, 05:53:12 am »
+ 1 for standby BEFORE diodes
I like to have a doubled switch
one for each branch of the transformer
Kagliostro
Offline LooseChange
    • Fix Your Darn Amps
« Reply #4 on: April 11, 2010, 06:35:20 am »
IMO switch before the rectifiers is overkill.
Fender put them after the rectifiers and the first PS filter stage with no problems.
Call me Dan
www.fydamps.com
Offline chip
« Reply #5 on: April 11, 2010, 07:20:49 am »
If I leave out the standby switch, what are the risks?
« Reply #6 on: April 11, 2010, 07:51:38 am »
I don't see any risks on a 2x6L6 amp. The STBY is more of a convenience (I like it) for a 40 watt amp.
« Reply #7 on: April 11, 2010, 08:49:00 am »
Man its tradition, ya dont buck tradition.  Just follow it, dont ask questions...
 :wink:
Offline Fresh_Start
  • noob de Lux
« Reply #8 on: April 11, 2010, 01:07:14 pm »
Would a 3-watt 220K "bleeder resistor" somewhere between the power rail and ground help limit the initial voltage surge in an amp without a standby switch?
Don't know where I got that I idea.  I've also seen those bleeder resistors located at the reservoir cap (1st after PT) and at the last (preamp) end of the power rail.
I see the two pairs of 220K resistors in series on both sides of the Standby switch in the OP's schematic (R26, 27, 28 & 29).  Obviously those serve as "bleeder resistors" even though they are there for another purpose. BTW what is the wattage rating on those resistors going to be?
Chip
Quote from: jjasilli
Quote from: PRR
