September 14, 2026, 02:57:29 pm
Hoffman Amps Forum image Author Topic: To pipe or not to pipe  (Read 6708 times)
Offline duke of earl
  • Bird is the Word
« on: April 14, 2010, 09:20:49 pm »
I just received some salt and pepper grille cloth. I have never wrapped a baffleboard and was wondering how well this stiff cloth will wrap around the board. Should I pipe it or will it bend enough for a clean job?
Offline JayB
Re: To pipe or not to pipe
« Reply #1 on: April 15, 2010, 08:38:58 am »
It will wrap around a board pretty good. Just have to pull it tight enough. The thicker cloth can be a bear to pull tight. Give yourself plenty of extra cloth around the sides to grab onto.
You're going to hell faster than Britney Spears running to a Barber shop
  • Bird is the Word
« Reply #2 on: April 16, 2010, 08:56:10 pm »
How much gap should I leave between the cabinet and baffleboard for the cloth with and without piping?
Offline tubesornothing
« Reply #3 on: April 16, 2010, 09:15:15 pm »
With that cloth, I leave almost 3/16".  You can experiment with a little piece of cloth and a snippet of the piping, just dry fit your baffle board and fit the piping and cloth "sandwhich" on either side to check fit.  Trim the baffle as required.
There are a couple of good threads on getting grill cloth tight.  Also check out the thread on piping as well.  Some good tricks.
  • Bird is the Word
« Reply #4 on: April 16, 2010, 09:37:23 pm »
Thanks Tubes!
