August 29, 2026, 08:52:06 am
Hoffman Amps Forum image Author Topic: JTM45 PT  (Read 9507 times)
Offline Direwolf
  • Don't murder me...
JTM45 PT
« on: April 14, 2010, 10:44:54 pm »
Hey, folks. My next build is going to be a JTM45. From what I can tell, the PT should be ~700v@200ma, 6.3v@5a and 5v@3a and I can get it from Edcor without having to pay the setup fee. Anybody have any input? Should I go with more or less B+ or higher current capacity? I'm going to build it from the original schematic so it won't have any mods initially that would affect power. I'll be using 3-12AX7 and 2-KT66 with a GZ34 rectifier.
Doc
« Last Edit: April 14, 2010, 10:59:04 pm by Direwolf »
Semper Fi
Re: JTM45 PT
« Reply #1 on: April 15, 2010, 12:10:02 am »
I think the original HT winding was more like 325-0-325 (@200mA) FWIW (because its a straight copy of a 5F6A after all - albeit with mustard caps, celestion speakers and Brit made trannys) but 350-0-350 will be okay too 2CW
Offline Leevi
    • Rikstone
Re: JTM45 PT
« Reply #2 on: April 15, 2010, 12:13:07 am »
The PT should be center tapped 350V-0-350V which means that after rectifier and filtering the voltage is on level 490V which sounds OK.
If you rectify the 700V with a bridge the voltage will be ~980V which is too much. 200mA sounds OK, see the the data sheet of KT66
http://tdsl.duncanamps.com/pdf/kt66.pdf
/Leevi
Offline Direwolf
Re: JTM45 PT
« Reply #3 on: April 15, 2010, 12:40:59 am »
Thanks, guys. I looked at Mercury, Weber and Hammond's specs and figured I was close with the numbers I came up with. What would be the optimal primary OT impedance, 3.4k or 6.6k? I see where Mercury has an OT with multiple primary taps in case I wanted to switch to other tubes but they're pretty expensive.
Doc
Semper Fi
Offline The_Gaz
Re: JTM45 PT
« Reply #4 on: April 15, 2010, 02:12:05 am »
Magnetic Components makes a nice PT, and can be picked up here http://shop.amppartsdirect.com/
Lower wattage and higher primary Z will yield less power (455 * 455 / 6600 watts thereabouts), but you don't see *accurate* clones of these using lower primaries like the typical 2xEL34 Marshalls do. Personally, I'd go with the higher voltage and impedance, but it depends on much 'headroom' you want.
Offline Direwolf
Re: JTM45 PT
« Reply #5 on: April 15, 2010, 11:07:59 am »
Thanks for the tip on the transformer, Gaz. I see it's only got 2a on the 5v winding, though. That's cutting it close using the GZ34 as it draws 1.9a. That's one reason I wanted to go with the Edcor.
Semper Fi
Re: JTM45 PT
« Reply #6 on: April 15, 2010, 11:29:50 am »
Edcor USA makes good transformers. I bought one online for my Ampeg Gemini II last year. BUT! They have to make them per order so expect a 4 week or more delay before recieving it. The told me over the phone that they stock no transformers and are made per order / That was my experience
Offline Direwolf
Re: JTM45 PT
« Reply #7 on: April 15, 2010, 12:47:03 pm »
I used them for a 5E3 build that I did a couple of years ago and love their transformers. You're right, it does take a few weeks to get them but it's worth the wait. They charge a setup fee if they haven't wound one to your specs before but after that there's no setup fee. The PT I mentioned earlier is already available so I wouldn't have to pay the setup fee.
Semper Fi
Offline Direwolf
Re: JTM45 PT
« Reply #8 on: April 15, 2010, 08:59:13 pm »
Again, does anybody have any info on the best primary impedance for the KT66s? I've heard both 3400 and 6600 ohms.
Semper Fi
Re: JTM45 PT
« Reply #9 on: April 15, 2010, 09:27:10 pm »
JTM 45 output transformer 8K primary impedance for KT66 tubes
Offline Direwolf
Re: JTM45 PT
« Reply #10 on: April 16, 2010, 04:05:36 pm »
Thanks, plexi50!
Semper Fi
Re: JTM45 PT
« Reply #11 on: April 16, 2010, 07:19:21 pm »
Glad if i can help. I am in fact building the same amp as soon as the chassis gets here. I love EL34's but it's time for some good old KT66's
I have a China cabinet with a light that i am putting my amp chassis in when there done. Have 3 in there so far. This is extreme but i think i might be a reclusive whatcha call it Howard Huges?
Now i just need his money to go with it and im set. Doing a tube section as well as a display
This may prevent me from selling them as well. Dont ask how thats gona stop me :wink:
Offline Direwolf
Re: JTM45 PT
« Reply #12 on: April 19, 2010, 10:25:23 pm »
Where are you getting your chassis from, plexi50? I'm torn between getting one that is like the original and one larger so I can add some mods later on if I want too.
That sounds like a sweet China cabinet! Much better than, well, china in it!
Semper Fi
