August 29, 2026, 08:49:06 am
Hoffman Amps Forum image Author Topic: high low jack question ?  (Read 5024 times)
Offline john_t
« on: May 05, 2010, 05:22:29 pm »
I am about to wire up my ga5 schedule 40 build. I have decided to use two jacks. The diagram/ info here shows the correct wiring for two jacks with ground switch and tip connections. I have one jack G S T and one with ground and tip only. If my input # 2 has only a ground and a tip lug can I put both the jumper wire from tip #1 and my 68K both on the tip lug of the # 2 jack.
I hope some one gets this
Offline phsyconoodler
Re: high low jack question ?
« Reply #1 on: May 05, 2010, 06:03:28 pm »
i hope you are using a 1 meg resistor on the high jack.
  If you are,then yes,you can run a wire from one to the next.
Offline john_t
« Reply #2 on: May 05, 2010, 06:57:25 pm »
phsyconoodler, thanks for the help. Yes I have the 1meg for jack #1. So I just was not sure about putting both on the tip of jack #2 as the info her shows the jumper going to the S lug on jack #2 and the tip out with the 68k, Il just put both on the tip.
john
