September 16, 2026, 01:28:40 pm
Hoffman Amps Forum image Author Topic: trem roach orientation please  (Read 7292 times)
Offline dwp
  • am addicted to iron........
« on: May 29, 2010, 12:25:56 pm »
Hello All, I did try search before asking this same question which I know was answered years ago, The copper leads on the trem roach go to the plate/voltage? silver to the pot and ground? Or am I backwards once again?
Thanks in advance, dwp
Offline Iannone
  • If it's too loud, you're too old
Re: trem roach orientation please
« Reply #1 on: June 04, 2010, 10:38:30 am »
The optical connections on the roach (which are non-polarized) are identified by the silver dot and the somewhat longer leads.  These are connected in shunt between the plate of the 12AX7 and ground.
Offline dwp
« Reply #2 on: June 04, 2010, 12:02:32 pm »
Thanks Iannone, so silver dot there is none, nor continuity or polarity on either, but I think the silver leads are the same as silver dot you are referring to, they were longer, this is and old roach I had installed and removed and was pondering re-installing, Have since moved on away from trem again.
Thanks again, dwp
